Honda CR-V & Element 2WD & 4WD Element & CR-V
2011 CR-V ac mix door actuator pinout
Old May 30, 2021 | 06:39 AM
cp96st's Avatar
Icon5 2011 CR-V ac mix door actuator pinout
Where can I find the wiring harness diagram for the ac mix or temp blend door actuator? (Driver side near the accelerator pedal)
What is the part number or MRF part number of the connector?
What pinout tool part number would remove the pins?
At the wiring harness connector I'm getting + and - 12 volts at the connector when adjusting the temp dial, but I can't ensure the motor is getting voltage when connected.
Also, with a 9 vdc battery, I proved the original and new actuators are working. The pinout seating/connections in the wiring connector appears faulty causing an intermittent connection when the harness is connected to the acutator?
MDUNN250
Jun 6, 2013 02:46 PM
Vagitarian
Dec 24, 2012 07:11 PM
Minjin
Jun 3, 2008 04:49 PM
CaptivaBlue
10
Feb 27, 2005 10:24 AM
blackekhatch
Oct 22, 2004 10:53 AM
