OBD0 DPFI to OBD1 MPFI Distributor guide (Direct 5 to 7 wire)
Hi all, this will be a wiring guide for the 5 wire obd0 dpfi square distributor plug to the 7 wire obd1 distributor plug, to use your obd1 distributor on your OBD1/MPFI Swap WITHOUT using the obd0 mpfi 7 wire circle plug many of the guide suggest you use.
ANY QUESTIONS PLEASE REPLY TO THREAD! I WILL TRY TO HELP AS MUCH AS POSSIBLE
Supplies you will need:
-OBD0 Distributor side plug
-OBD1 Distributor plug(engine harness side clip)
-OBD1 Distributor
-Solder, shrink wrap, wiring supplies
So for the OBD1 swap you will go from 5 wires to 7 wires, the 2 extra wires coming out of your distributor will go to pins C1 and C2 in your new OBD1 ECU
The 2nd 2 wire plug is self explanatory, Blue wire to blue wire, and black/yellow to black/yellow, don't worry about the wire size difference for the black/yellow wire
Re: OBD0 DPFI to OBD1 MPFI Distributor guide (Direct 5 to 7 wire)
Thank you for posting this! its been the only thing i can find on this 5 plug dizzy wiring. Im needing a little help on my swap that im in the middle of im hoping to get a reply even tho its been awhile since you have made this post... so the ? i have is when i wire the dizzy into C1 and C2 do i need to unpin the existing wires that go to A18 and A15 on the obd0 harness or do i leave those wired in and use the extension on the obd0 to obd1 conversion harness that has the extra c1 and c2 connections going to it
Im glad the post is kinda helping someone!
that is a good question! I actually sold my car about a year ago- im thinking my jumper had c1/c2 blank and i wired them straight to the ecu. This is good timing of the post, because my car just was sold to back to someone that goes to my university. I will take a peel at it next week! Ill let you know!
thanks man i really appreciate it big time i try to post some pictures of exactly what im talking about aswell!
C1 and c2 it says it’s a b connector but it’s the c the small one A 15 and A 18 are the obd0
But the obd0 to obd1 jumper harness I got has the extension harness for your own stuff to be wired in and the c1 and c2 are connected to it... I just don’t wanna fry any computer stuff.
Created an account just to help with this thread to add additional info to it.
The additional wires can go to different locations depending on which ECU plug you need.
OBD1 dizzy wiring
White= Cylinder position Mass
White/Blue= TDC Mass
Blue/Yellow (new wire)= Crank position Mass
Orange= Cylinder position pulse
Orange/Blue= TDC pulse
Blue/green (new wire)= Crank Position Pulse
Green/yellow= 5v feed
OBD0 dizzy wiring (5 wire)
Tan(whiteish)= TDC mass
White= TDC pulse
Blue = Cylinder position mass
Blue/yellow= Cylinder position pulse
Crank position signals missing from 5 wire, Crank position wiring needs adding Wiring needs adding to pins B10 and B12 on OBD0 ECUORpins B15 and B16 on OBD1 ECU
**The Blue/Green wire needs wiring to pin B10 on OBD0 connector or B15 on OBD1 jumper harness connector**
**The Blue/Yellow wire needs wiring to pin B12 on OBD0 connector or B16 on OBD1 jumper harness connector**
Finally got the engine running now. I had an issue where the CYP (Cylinder position) and CKP (Crank position) wires were the wrong way round causing the engine to run horribly. If you encounter this issue, the easiest way to fix it is at the distributor. In my case the CKP wires were Orange and white, and the CYP wires were Blue/Green and Blue/Yellow. re-pinning the connector at the distributor and swapping these wires around fixed the issue for me!
