Low boost on stock y7??
I don't know the turbo brand, but its a journal..wet gloating bearing turbo or something like that? Its completely my first time doing this, don't have much money to build the engine right now, but I want to slightly feel and hear a turbo, without killing my only motor..so I wonder if 5psi is overkill considering its automatic and bone stock ya know. Thanks for any and all help
Automatic SOHC, no money for a proper build engine, and you don't know any real details about the turbo. You're also indicating that you haven't even considered tuning it, and are just going to randomly throw on a MBC.
This will not go well if you choose to proceed.
What is your budget? You can use an FMU and a missing link and you'll probably be OK. Or you could buy an AFC. It's old tech, but it will work for your goals. If going this route, I would HIGHLY recommend running a wideband oxygen sensor so you can know when you're beginning to tax your (mostly stock) fuel system and let out before you blow it up. Resist the urge to turn it up without proper tuning.
Either way I think you're going to find that even trying to skimp by, it's going to be more expensive than you thought.
From what I was looking at regarding the turbo and the specs of it, 245hp @10psi and I have 550cc injectors and a walbro 255lph fuel pump ready to install as well. I just would like to cruise around listening to the turbo itself blowoff lol without killing my engine. I'm looking into tuning for it also. Thank you for the help. Its definitely costing me as I go though just trying to get setup for this project
If you have 550cc injectors already, I don’t know what kind of engine management system tuning software to use since it’s an automatic. The Apexi AFC (Hack as it’s called because it tricks the stock computer) can control up to 440cc injectors. MAYBE 550cc if you can put it to -100% for idle or just lower your base static fuel pressure with a fuel pressure regulator...
The tough part about automatic Hondas is that there isn’t much support for tuning them. But, the FMU is what I suggest for 5psi with a T3/TO4E. But don’t really try to go above 8psi of boost with it.
A turbo kit that has quality components and is reasonably priced is this one:
GO-AUTOWORKS Street Turbo Kit Honda Civic Acura Integra Del Sol CRX D16 B16 B18
Try to avoid the eBay brand turbos or the no-name, non reputable turbo chargers because they have lots of problems.
Thanks bro. The turbo I received has no direct name on it to identify it by, and I'm not sure what size wastegate spring is already inside the wastegate. But, the kit included a manual boost controller and a boost gauge. Will that stock y7 handle 8lbs?? On 550cc injectors and the 255lph fuel pump?
If I were you, and what I did, was use the stock fuel injectors and computer with the Vortec 10:1 rate Fuel Management Unit (FMU), and the Walbro 255 liter per hour fuel pump (the one rated for high pressure is better for this application).
The engine itself should be able to handle the power.
For the wastegate, does it have a name brand in it? If not, it might be a Tial 38mm replica/copy, there are a lot of copies out there. Some work fine actually. If it is a copy, then the Tial wastegate springs might work and might be the same. This goes for Tial wastegates, but yours may be the same if it looks like this externally. And if you get the right spring, then you don’t need the manual boost controller. Manual boost controllers are only for increasing the boost.
[img]blob:https://honda-tech.com/3048cdec-ce16-4830-88b1-cfd8f3a4cd50[/img]
Last edited by highschooler; Apr 10, 2021 at 08:16 PM. Reason: Picture didn’t show up the first time, so I added it.
It is not a question of whether or not your stock Y7 can handle 8lbs, it is how you plan on tuning, (first) and whether or not your autotragic transmission is going to grenade on your first WOT pull. The FMU is a viable option but, I'm pretty sure you'll need to use your stock injectors for this. I have no personal experience to ANY plug and play injectors that you can install and they work as designed with no actual engine management setup; Piggy-back unit or chip burn..
Have to be able to monitor your AFR, so you'll need a wideband as well.. I'm normally not the one to discourage but, this has "no" written all over it.
Sci_v_icI
Mar 28, 2006 08:07 PM
TegDude
12
Dec 7, 2004 05:50 PM
