Weird issues - 95 Civic dx d15b7
Old Apr 3, 2021 | 11:51 AM
William2574's Avatar
Default Weird issues - 95 Civic dx d15b7
I’m stuck in that weird “limp” mode where it wont rev past 4K and it acts like a fuel cut and makes extreme popping like almost a launch control of some sorts. I bought the car off of some guy a few towns away and drove it fine back. It had a rough idle and all sorts of issues. The cel is on and I’ve made plenty of attempts to read it by shorting the connector but nothing flashes at all. I’ve changed to another cluster to try and see if it helps but all it does is flash the srs for a few seconds and then leaves the engine light solid. Also sometimes when I short it it doesn’t do anything at all. Idle sits somewhere around 8-1100 rpms but as I tap the gas it’ll rise and rise to a top of 1800. I’ve changed the iacv, map sensor, and just because the cluster wasn’t working for speed I changed the speed sensor and that fixed that. I know timing is off and it’s on the first mark but I can’t even get past it while the distributor is turned all the way towards the front. I’m just curious as to what’s another option I have. Could it be a bad ecu?
Old Apr 3, 2021 | 04:08 PM
tamboo's Avatar
10 Year Member
Default Re: Weird issues - 95 Civic dx d15b7
if the distributor is not dialing it in then your
timing belt likely skipped a notch or 2 on the intake cam.
set crank at timing mark, remove valve cover and check cam alignment.
Old Apr 3, 2021 | 05:52 PM
I appreciate the follow up. I’ll take a look Wednesday and when I’m off and go through with it.
dirtyundies
13
Jun 19, 2017 05:40 PM
Kaminsky
14
Aug 7, 2015 03:03 PM
Bakuryu06
Sep 21, 2010 09:22 AM
Dokta
Dec 23, 2009 07:51 PM
Infinity_Racer
Sep 20, 2004 06:02 PM
