Honda CR-V & Element 2WD & 4WD Element & CR-V
'05 CR-V: Flurry of Codes, but Vehicle Runs Fine...
Old Mar 25, 2021 | 11:22 AM
CoolBreezeRandy's Avatar
Default '05 CR-V: Flurry of Codes, but Vehicle Runs Fine...
...for the moment, at least. 2005 CR-V AWD VTech, ~150k. About a week ago, I started getting the check engine light popping on, and the VSA/traction control lights lighting up 30-60 seconds thereafter. I had the codes scanned at the local parts store, and came up with the following:
62-1 ABS Battery Voltage High Malfunction
83-1 ECM/PCM Relation Failure
86-1 controller area network relation malfunction
P0011 Camshaft Positions sensor
etc, etc
But here's the thing: the vehicle is running just fine. There's no new lugging or hesitation I can sense; the lights just pop on and the car runs merrily along. A cursory sweep of 'Net resources suggests a communication error of some sort. A corroded plug somewhere? Any assistance is appreciated, thanks.
Old Mar 26, 2021 | 01:12 AM
Davey7847's Avatar
Default Re: '05 CR-V: Flurry of Codes, but Vehicle Runs Fine...
Check your battery voltage ( running at idle and at 3000 rpm). Possibility of a faulty voltage regulator in the alternator.
....first clue is the high voltage code; abnormal voltages high (or low) will trip codes as sensors will be sending higher voltages back to the PCM which in turn the PCM will read and report as high sensor voltage readings.
Check all the battery connections and check all the grounds to the block and frame from the battery as well.
Old Mar 26, 2021 | 02:52 PM
That makes sense, thanks.
knightfan17
Nov 7, 2021 05:53 AM
Stryk3r420
Jan 30, 2010 05:35 PM
2fast2accord98
Nov 21, 2005 04:36 AM
Teglessb18
Jul 8, 2005 01:46 PM
g1guitarguy
Apr 21, 2004 01:02 PM
