95 Accord EX Wont start after Jumped Battery!!! STUCK OUT OF TOWN NEED HELP ASAP
Left lights on battery died after getting a jump the car won't start lights are working, anti theft indicator light on dash blinks 3 times, alarm works, changed the 7.5 amp fuses for ECU and starter located in fuse box under driver side dash, tried the toggle switch next to that fuse box I believe it's for the alarm. I do not have a key fob only ignition key tried the anti theft reset lock and unlock driver side door using key, and turning ignition from off to on .. in Dec this car was stolen since recovering it I have to use shift lock to switch gears and the power windows, and speedometer and gauges on dash and radio wont work... What Next?
A couple of things :
Check fuses, especially under the hood, I believe there is a 20amp fuse that gets blown and can stop you from shifting out of park.
Also, look behind the brake pedal, there is usually a little piece there that gets broken and if it doesn't get engaged it won't let you take it out of park normally.
zang8027
Nov 25, 2009 09:49 AM
