Y7 to Y8... is it even a Y8!?
Old Mar 15, 2021 | 02:34 PM
mikey shea's Avatar
Default Y7 to Y8... is it even a Y8!?
Hi guys,
I am hoping someone can help me!!
I have a D16Y7 and am looking to do the Y8 upgrade. I bought what was advertised as a Y8 intake Manifold but its not like any other Y8 I have seen.
On the front the holes are different to any other Y8 I have seen and has a sensor on the top!?
Is it still useable? And what is it!?
TIA
Old Mar 15, 2021 | 07:23 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Y7 to Y8... is it even a Y8!?
It looks like the right size plenum to be a Y8 equivalent.
Most likely guess is it's a JDM equivalent. They had basically the same motors with slightly different configurations, like an EGR where we didn't or something of such sort.
I'd say it is usable and if the sensor/valve or whatever it is on the top of the plenum isn't part of your Y8. Then I'd suggest removing it and plugging the holes that go into the plenum.
Old Mar 15, 2021 | 09:51 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The purge control solenoid mounted to the top of the plenum may be ugly, but it won't matter with respect to installation. The real key with the I/M that you have pictured above is that it is a '99-00 Y8 manifold. What differentiates it from a '96-98 Y8 I/M is the 5/16" vacuum port in the middle of the casting. This is connected to a vacuum accumulator rail inside the mounting flange of the I/M. This system doesn't work on a '96-98 Y8 cylinder head and will cause a HUGE vacuum leak. You "MAY" be able to plug off this system somehow and make it work... many have tried and usually fail. So I have found that it is best to just get an I/M that MATCHES the flange on your cylinder head. So look at the machined gasket surface on your cylinder head: If it has a flat horizontal edge across the top and 4 tiny holes in the gasket leading to the gap there... you have a '99-00 cylinder head, so you must have a '99-00 I/M to go with it. IF the gasket basically only surrounds the intake runners and has no long flat edge across the top... you have a '96-98 cylinder head, which means you must have a '96-98 Y8 I/M.
Any questions ?
Old Mar 28, 2021 | 05:00 AM
mikey shea's Avatar
Any questions ?
So are these the holes you are on about? I have seen many people blank these off and suceed.
My main query is the male vac fitting on the top right? Where does this connect to and from?
StuckInTexas
Feb 12, 2015 10:38 PM
SOHC_civic_si
May 4, 2008 08:50 PM
soulforce
Jul 17, 2006 12:41 AM
freakasis
12
Mar 5, 2006 08:11 AM
Steve91
Jul 16, 2003 09:15 AM
