F23Z5 Engine pistons
Old Mar 6, 2021 | 01:25 AM
FranJer1's Avatar
Default F23Z5 Engine pistons
Hi, I have been doing some digging and wonder if anyone has considered using the pistons from the Honda accord type V as the compression ratio is 8.8-1. looking to bore and sleeve to 87mm to match the size.
Would like to know if anyone has attempted this and if so what should I take into consideration.
Thanks
Old Mar 6, 2021 | 10:05 AM
Txdragon's Avatar
Default Re: F23Z5 Engine pistons
Thanks
Use those pistons in what? Why on earth would you want such low compression?
Old Mar 7, 2021 | 10:16 AM
FranJer1's Avatar
Would be using it on a Bored 87mm K20. it's a learning process, but I take it @Txdragon you'd recommend differently.
Old Mar 7, 2021 | 03:33 PM
Txdragon's Avatar
Used for? I'm assuming boosted application? Gotta give some plan details, amigo.
Old Mar 7, 2021 | 07:21 PM
FranJer1's Avatar
I ran a K20, sidewinder Manifold, GT35 Turbo, with stock internals, 1000cc inj Etc
Plan to rebuild to make more boost and a bigger turbo. Also thinking of going AWD in the future.
Cayou91
Acura TL, RL & ZDX
Jul 8, 2020 07:46 AM
Vtec04
May 21, 2017 08:19 AM
djking
Aug 14, 2010 07:44 PM
Hy-wind
Dec 2, 2004 04:18 AM
HX_Guy
Nov 9, 2001 11:55 AM
