1996 civic ex speedo
Old Feb 25, 2021 | 01:03 PM
Jakeknight's Avatar
Default 1996 civic ex speedo
Hello I have a 1996 civic ex coupe and the speedometer does not work, everything else does but not my speedo I just replaced the speed sensor on the trans and that didn't fix it, I was going to check the plug to see if its getting electricity through it but don't have a tester, I replaced the whole cluster as well, what other reasons could it be not reading the speed.
Old Feb 25, 2021 | 05:17 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: 1996 civic ex speedo
You have a break in the signal! you need to find where your loosing the signal. Look at the plug itself and inspect it for any cuts or breaks! Also make sure the prongs are making full contact when the plug is plugged in the speed sensor.
Old Feb 25, 2021 | 08:19 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The signal is a square wave so a regular volt ohm meter will not work beyond continuity testing of the wire(s).
Very often the circuit board on the back of the speedometer goes bad. It is possible you got a cluster with a bad board and saw no change when you swapped them out. But first you need to rule out a break or short in the wires.
blockaustin84
May 29, 2018 09:01 AM
rice117
Mar 26, 2011 05:13 PM
thecruzs2007@yahoo.com
14
Aug 17, 2009 09:07 PM
so simple
Jan 17, 2008 02:03 PM
imadigitalgod
Oct 31, 2004 02:57 AM
