Toda Spec A2s on mostly stock GSR?
Old Feb 15, 2021 | 11:00 PM
KilowattBandit's Avatar
5 Year Member
Default Toda Spec A2s on mostly stock GSR?
Just curious: has anyone here know how the Toda Spec A2s would do on a mostly stock GSR? All it has are Supertech 75 lb dual valve springs, steel retainers, ARP head studs, OEM head gasket, AEBS intake manifold, 68 mm throttle body, CT Engineering Icebox, and ITR intake arm. Any complications from stock compression ratio, piston/valve clearance, etc? I also read that Toda valve springs "must" be used. Thanks!
Old Feb 16, 2021 | 07:26 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: Toda Spec A2s on mostly stock GSR?
Naw that'd be fine
Old Feb 16, 2021 | 08:23 AM
5 Year Member
Originally Posted by 2LEM1
Naw that'd be fine
Thanks for the reply. If that's the case I assume the A2s are basically drop in cams?
Old Feb 16, 2021 | 09:36 AM
2LEM1's Avatar
I like to party
Community Builder
Indeed, they are a bit larger than Skunk2 Tuner 1s if I recall, and those can be run on ITR valvetrain. The Supertech springs should be plenty fine, 75lbs is enough for much larger cams.
edit:
B16 -
Intake lift - 10.34
Intake duration - 235
Exhaust lift - 9.44
Exhaust duration - 230
ITR (96-97) -
Intake lift - 11.45
Intake duration - 240
Exhaust lift - 10.52
Exhaust duration - 235
CTR/ITR (98+) -
Intake lift - 11.4
Intake duration - 243
BISI Level 3+ CAMS -
Intake Lift - 12.2
Intake Duration - 276
Exhaust Lift - 11.7
Exhaust Duration - 276
Buddy Club Spec 3 -
Intake lift - 11.6
Intake duration - 304
Exhaust lift - 10.7
Exhaust duration - 294
Buddy Club Spec III+ -
Intake lift - 11.4
Intake duration - 250
Exhaust lift - 11.8
Exhaust duration - 245
Buddy Club Spec IV -
Intake lift - 12.3
Intake duration - 266
Exhaust lift - 11.8
Exhaust duration - 262
Buddy Club Spec VI -
Intake lift - 11.8
Intake duration - 253
Exhaust lift - 11.9
Exhaust duration - 243
JUN III -
Intake lift - 12.0
Intake duration - 265
Exhaust lift - 11.5
Exhaust duration - 265
Spoon Sports High Cam -
Intake lift - 11.5
Intake duration - 256
Exhaust lift - 11.1
*Skunk2 Tuner1 -
Intake lift - 11.6
Intake duration - 252
Exhaust lift - 10.9
Exhaust duration - 249
*Skunk2 Tuner2 -
Intake lift - 12.3
Exhaust lift - 11.8
*Skunk2 Tuner3 -
Intake lift - 12.8
Intake duration - 273
Exhaust lift - 11.5
Exhaust duration - 273
*Skunk2 Pro1 -
Intake lift - 12.6
Intake duration - 257
Exhaust lift - 11.6
Exhaust duration - 263
*Skunk2 Pro2 -
Intake lift - 12.5
Intake duration - 263
Exhaust lift - 11.6
*Skunk Pro3 -
Intake lift - 12.7
Intake duration - 270
Exhaust lift - 11.9
RM24x -
Intake lift - 12.0
Intake duration - 268
Exhaust lift - 12.0
Exhaust duration - 268
RM25x -
Intake lift - 12.0
Intake duration - 275
Exhaust lift - 12.0
Exhaust duration - 275
Toda Spec A
Intake lift - 11.6
Exhaust lift - 11.2
Exhaust duration - 240
Toda Spec B
Intake lift - 12
Intake duration - 255
Exhaust lift - 12
Toda Spec C
Intake lift - 12.5
Exhaust lift - 12.5
Exhaust duration - 255
Old Feb 16, 2021 | 03:06 PM
5 Year Member
Thanks again! Really appreciate the inclusion of the different cam specs for comparison. However, the specs listed are for the Toda Spec A, not the A2. JHPUSA lists the A2 specs as:
Intake cam: Duration 295mm / 12.0mm Lift
Exhaust cam: Duration 285mm / 12.0mm Lift
Duration is similar to the Buddy Club Spec III+ (which is what I wanted before I found out they were discontinued long ago) and lift just a bit larger than the Tuner 1. I'm hoping that difference between the A and A2 isn't enough to pose as a problem. Ideally I'd build the engine around the cam but I simply can't just pull the motor out and I'd rather have a drop in solution.
Old Feb 16, 2021 | 04:25 PM
2LEM1's Avatar
I like to party
Community Builder
IDK what JHP is talking about, those aren't even close to real cam specs, that would blow up a motor with that duration and lift.
I assure you my specs are correct, and AFIK there's no difference between A and A2 cams.
https://www.ek9.org/index.php?thread...s-engines.137/
Old Feb 16, 2021 | 05:52 PM
5 Year Member
Thanks for the clarification. Admittedly I don't know that much about camshaft specifications and just assumed that those measurements were done at something other than 1mm of lift but looking at it they still seem too high anyways. If the A and A2 are the same I'll have to get them in the future instead of going turbo. I wanna keep things simple and reliable lol
Old Feb 16, 2021 | 06:58 PM
hybridnorth's Avatar
A2 have 295 duration compared to 280 on the Toda A for the vtec lobe, idle characteristics will be the same for both, very similar to oem. Both can use oem ITR valvetrain without issue
Old Feb 16, 2021 | 08:49 PM
2LEM1's Avatar
I like to party
Community Builder
I just checked Toda's website. The A2 cam has the Type B VTEC lobe with the Type A primaries. Kinda a weird cam. I guess it's for people that daily and need that good mileage on the small cam but more more power at crossover.
Old Feb 17, 2021 | 12:13 PM
TheShodan's Avatar
Moderator
JHPUSA has fallen off for quite a bit. Those specs are way off.
Attached via PDF file are the actual Spec A Sheets. (The A2 was basically the same thing)
Old Feb 17, 2021 | 02:33 PM
2LEM1's Avatar
I like to party
Community Builder
I think that's advertised duration. It does seem the lift is correct though.
According to Toda's website the A2 cam has the Type A small cam and the Type B big cam. That crossover must be wild lol.
Old Feb 18, 2021 | 06:34 AM
TheShodan's Avatar
Moderator
I've owned both the A & A2s. The application is different than the theory. The crossover is nice, smooth and even. The Tuner 1s were actually more aggressive than the Toda A or Toda A2, but allowed for more power.
SoFresh1189
Feb 20, 2010 10:07 AM
movingIIshadow
May 23, 2006 03:05 PM
djraverboy
Jan 23, 2006 09:36 PM
TRuST
Feb 15, 2003 05:03 PM
Malice
Jul 15, 2002 06:12 PM
