Cam Specs: Toda, Spoon, Skunk2, ITR, CTR
Cam Specs: Toda, Spoon, Skunk2, ITR, CTR, JUN
I complied a list of cams specs from either their repective web sites or postings, but I would like you opinion if these specs are correct ? Or if you could provide the mugen, or another cams specs to add to the list.
Toda A's
INTAKE lift - 11.6 mm, duration - 250 @ 1mm
EXHAUST lift - 11.2mm, duration - 240 @ 1mm
Toda B's
INTAKE lift - 12 mm,duration - 255 @ 1mm
EXHAUST lift - 12 mm, duration - 245 @ 1mm
Toda C's
INTAKE lift - 12.5 mm,duration - 255 @ 1mm
EXHAUST lift - 12.5 mm, duration - 255 @ 1mm
Toda Spec D
INTAKE lift - 12.9 mm, duration - 268 @ 1 mm
EXHAUST lift - 11.9 mm, duratin - 272 @ 1 mm
Jun Type 1
INTAKE lift - 10.9 mm, duration - 265.3 @ 1mm
EXHAUST lift - 10.0 mm, duration - 268 @ 1mm
Jun Type 2
INTAKE lift - 12.0 mm, duration - 266.6 @ 1mm
EXHAUST lift - 10.9 mm, duration - 265.3 @ 1mm
Jun Type 3
INTAKE lift - 12.0 mm, duration - 265.3 @ 1mm
EXHAUST lift - 11.5 mm, duration - 265.3 @ 1mm
Spoon Integra VTEC cam
INTAKE lift - 11.53 mm, duration - 256 @ 1mm
EXHAUST lift - 11.13 mm, duration - 245 @ 1mm
Skunk2 cams
Stage I
INTAKE lift- 11.58 mm, duration 252 @ 1mm
EXHAUST lift - 10.9 mm, duration 249 @ 1mm
Stage II
INTAKE lift- 12.07 mm, duration 265 @ 1mm
EXHAUST lift - 11.6 mm, duration 256 @ 1mm
Stage III
INTAKE lift- 12.7 mm, duration 273 @ 1mm
EXHAUST lift - 11.5 mm, duration 273 @ 1mm
Crower 63403
INTAKE lift - 11.98 mm, duration - 246 @ 1mm
EXHAUST lift - 11.83 mm, duration - 238 @ 1mm
ITR
INTAKE lift - 11.5 mm, duration - 240 @ 1mm
EXHAUST lift - 10.5 mm, duration - 235 @ 1mm
CTR
INTAKE lift - 11.5mm, duration - 243 @ 1mm
RS cams
INTAKE lift - 12mm, duration - 294
Exhuast lift - 11.5mm, duration - 296
Modified by TRuST at 12:28 PM 7/6/2003
Toda A's
Toda B's
Toda C's
Toda Spec D
Jun Type 1
Jun Type 2
Jun Type 3
Skunk2 cams
Stage I
Stage II
Stage III
Crower 63403
ITR
CTR
RS cams
Re: Cam Specs: Toda, Spoon, Skunk2, ITR, CTR (TRuST)
Toda A's
Toda B's
Toda C's
These are the correct figures
[Modified by sgT, 1:01 PM 10/31/2001]
Toda B's
Toda C's
You forgot the JUN cams! (checked their website but nothing is listed there in terms of cam specs for Honda....everything but actually)
Re: Cam Specs: Toda, Spoon, Skunk2, ITR, CTR (Big Phat R)
TYPE1
INT (300) 10.9
EXH (300) 10.0
TYPE2
INT (300) 12.0
EXH (300) 10.9
TYPE3
INT (304) 12.0
EXH (304) 11.5
All of the duration figures are TOTAL duration. not at lift.
INT (300) 10.9
EXH (300) 10.0
TYPE2
INT (300) 12.0
EXH (300) 10.9
TYPE3
INT (304) 12.0
EXH (304) 11.5
Re: Cam Specs: Toda, Spoon, Skunk2, ITR, CTR (sgT)
I know what duration and lift is, but how is it related to their performance or the type of powerband they produce ?
I figure more lift and duration gives better topend performance at a higher RPM compared to a cam with less lift and duration.
Re: Cam Specs: Toda, Spoon, Skunk2, ITR, CTR (SpecR_EK)
THESE ARE TOTAL DURATION FIGURES
TYPE1
INT (240) 5.3 (300) 10.9 (256) 8.5
EXH5 (260) 8.0 (300) 10.0 (244) 4.8
TYPE2
INT (240) 5.3 (300) 12.0 (260) 8.0
EXH (252) 8.0 (300) 10.9 (244) 4.8
TYPE3
INT (240) 6.5 (304) 12.0 (252) 9.0
EXH (252) 8.7 (304) 11.5 (240) 6.2
Spec A
INT (220) 6.0 - (290) 11.6 - (240) 9.0
EXH (220) 5.5 - (280) 11.2 - (240) 8.5
Spec B
INT (250) 11.0 - (295) 12.0 - (250) 11.0
EXH (250) 11.0 - (285) 12.0 - (250) 11.0
Spec C
INT (250) 11.0 - (295) 12.5 - (250) 11.0
EXH (250) 11.0 - (295) 12.5 - (250) 11.0
TYPE1
TYPE2
TYPE3
Spec A
Spec B
Spec C
Jun doesn't have alot of lift, but a sh*t load of duration.
[Modified by TRuST, 2:37 PM 10/31/2001]
New User
It is nice and cool to have all the cams spec, but can someone here explain to me what can I get out of from the cams spec and how can I use the specs to decide which cams is best for certain application or purpose?
Re: Cam Specs: Toda, Spoon, Skunk2, ITR, CTR (civicnightracer)
Here's my knowledge limited and rudementary explaination of lift and duration. (please correct me if I am wrong), but I'll give it a shot. Let's take the ITR cam and the Toda Spec C's cams for an example.
Lift: How high the valves move up and down.
Duration: how long the valves stay open.
Toda C's
ITR
If you think about it like this as your RPM goes up so does the RPMs of the cams. The higher the RPMs go the less time fuel and air is allowed into the combustion chamber. Now the higher lift and longer duration provides more time to allow fuel and air in at a high RPM compared to a cam with less duration and lift. Which is why a certain cams perform much better at a higher RPM than others.
How does this apply to our example. The ITR cam HP peaks around 8200 and doesn't produce any more power after 8200 rpms, where as Todas would continue to make power because of it higher duration and lift at RPM higher compared to the ITR cams.
Another, variable that I don't know much about would be the overlap, which is when both intake and exhaust valve is open. At this point, the cam designers try to use a scavenging effect to try to draw the exhaust out and cause a vacuum to suck in Air and Fuel.
Sorry, its a little incomplete but that my limited knowledge of cams.
Here's a link that goes over the basics of cams.
How cam's work
[Modified by TRuST, 3:05 PM 11/1/2001]
Toda C's
ITR
How cam's work
New User
Thanks for the info.
But I guess what I tried to get at is which one is more important? More lift or more duration. So what is the benefit for having a high lift, but little bit less duration, and what is the advantage for having high duration but less lift?
I ask because from the specs, this is the main different between JUN and TODA cams.
Re: Cam Specs: Toda, Spoon, Skunk2, ITR, CTR, JUN (TRuST)
Here's a website that I found listing all the specs for those cams http://www.allmotorhonda.com/techpages/camspecs.htm
itr-killer
09-25-2005 11:14 AM
KOTSEMOTO
07-17-2003 09:46 AM
