95 Lude F22B JDM Swap
Old Feb 10, 2021 | 12:58 AM
Stratious's Avatar
Default 95 Lude F22B JDM Swap
I know this has been covered several times, but had my F22A1 die, picked up an F22B JDM DOHC engine to swap in, currently going to just mate it to my M2L5, now the issue I'm looking at is the ECU is not going to work obviously, I'm hoping someone can point me to a good, reliable and cheap source for one that would work without too much hassle. I'd like to get one that's chipped just for future modifications, but I'm just focusing on getting it running again for now.
Old Feb 10, 2021 | 03:28 AM
TimiK's Avatar
Default Re: 95 Lude F22B JDM Swap
not really point to get that engine modded in future
but you probably need chipped P28, contact your local tuner to know what software hes using etc
Old Feb 10, 2021 | 07:46 AM
Stratious's Avatar
I'm already looking into options for both chipped and unchipped ECUs that would work, the problem is finding something that isn't going to cost me an arm and a leg to get it running while still being a legit ECU instead of a fake. I was hoping someone could point me to a place to pick up something cheap that's used.
Old Feb 10, 2021 | 09:01 AM
ross2004's Avatar
I bet a non-vtec H23 ECU would run it fine.
Old Feb 10, 2021 | 10:42 AM
Aradin's Avatar
Premium Member
Ross is correct. H23A1(P14) ecu will run it close to perfect. The engines are extremely similar.
Old Feb 11, 2021 | 06:10 AM
Stratious's Avatar
I'm aware a P14 would work, as well as any chipped P06, P28, P30, P72, P75 or PR4. Again, my issue is finding one that isn't a fake. Hoping someone can point me in the direction of one to buy, not just letting me know what would work.
Old Feb 11, 2021 | 07:51 AM
ross2004's Avatar
www.car-part.com
Old Feb 11, 2021 | 11:08 AM
Aradin's Avatar
Premium Member
If you must have a chipped ECU, xenocron or phearable are reputable and typically have them in stock. They will also include a basemap so you can get the car started to check for leaks prior to getting tuned. Basemaps are not for driving on. With a chipped ECU, a tune will be required for optimal results.
Old Feb 11, 2021 | 07:55 PM
TimiK's Avatar
https://www.hamotorsports.com/
phearable sold me faulty ecu
j4s0n1337
Dec 15, 2022 06:13 AM
spurge
Feb 20, 2006 10:19 PM
ELSpool
Oct 14, 2005 11:45 AM
projectegr
Dec 9, 2004 02:32 PM
Erod
Apr 20, 2004 12:38 PM
