Help about Engine block I acquired in storage unit
So I recently won a storage unit at auction and there’s a Honda Engine block in there, i looked up the Casting numbers and it said it’s for a 92-96 prelude 2.3L DOCH. I was just wondering what it’s worth in the condition its in right now. Any help is greatly appreciated.
Re: Help about Engine block I acquired in storage unit
Originally Posted by iwannarace
That's like 40lbs of aluminum. Should be $25-$40 at least, no?
Right now, clean aluminum might bring 35 cents per pound... but mixed metal only brings about 8 cents per pound. So if the OP removes all studs, bolts, valves, springs, retainers, passage plugs, dowels... and drills/hammers out all 16 valve guides... you might get close to $20. Otherwise, it will likely get you less than $5.
