Immobilizer issues PLEASE HELP
Good day to all.. I have a 2007 Civic LX w/ ~140k on it bone stock. Everything was fine until one day I went to start it and it stalled immediately. After doing some research, i figured out that I have an immobilizer issue. I had a somewhat weak battery, so I thought the car may have lost the program for the keys.
I used a Launch X-431 Throttle to reprogram the keys, but it tells me "Immobilizer System Is Not Normal" and "D-3 No Communication Between ECM/PCM And Immobilizer Unit".
I have checked every fuse, checked all connectors at the immobilizer MICU (fuse box) and ECM. All seem normal.
I really just want to bypass the immobilizer altogether and have been looking for wiring diagrams to figure it out, but I am not 100% confident I won't mess more things up. If anyone knows how to do this, PLEASE PM me with some guidance.
Otherwise, if there is a way I can test each piece individually so I don't have to replace them all, that info would be greatly appreciated.
TIA
TIA
Unfortunately.. it's still sitting in my garage. I found another 2007 Civic LX sedan in the junkyard. I got the ECU, MICU and the immobilizer. I used my Launch x431 to reprogram then all but I still get the same error code at the end.
Crazy thing is, I periodically just try to start it even though I haven't worked on it at all... And one day it started and ran. I drove it around a little. Shut it restarted it, drove it again. Next day, the problem was back.
i have ''D-3 No Communication Between ECM/PCM'' too but i can manage that by putting unregistered key and resulting to D1 but successfully sync the immobox and ecu you can try that method
Wow.. finally a response from someone that is actually having the same exact problem. So, I can get through the whole process right up until the end when I get D3. After that, I'm at a dead end. If I swap the immobilizer, I can start the process over until I got D3 again. Doesn't seem to matter which combination of pieces (ecu, micu, immobilizer) I have in. I've pinned out as many connections as I could figure out. I've gone through every troubleshooting step in the service manual. I've never had an automotive problem i couldn't figure out until this. I became so aggravated that it's just been sitting for 2 months.
Are you both using the same scan tool? Can you get your hands on an alternate tool? Or check for software updates on your tool? I have an Autel that has successfully programmed many immobilizer keys in this generation.
Maybe a suspect MICU. That sits between the immobilizer unit and the PCM on the S-NET communication line. This is the only communication line between immobilizer and PCM.
Are you able to try another car or another scan tool? It is very possible for the scan tool to have a bug in software on this specific generation of immobilizer.
I mentioned above that I've replaced (from same year and model car) and reprogrammed the ECM, MICU, and immobilizer. I've tried every combination of parts from both cars. If you read my post from yesterday, it comes up with D3 at the same point every time. It randomly started and ran one day even though I didn't change anything. Next day, back to the same problem.
ok.. first off THANK YOU for the response, but I have a few questions. , 1) how do i resolve the problem? I swapped the MICU already. 2) by what you're saying, this would occur whenever a battery goes dead or is replaced, no? 3) why did the car randomly start and drive one day?
I have two MICUs that were known good, an 06 CR-V and a 12 Civic. I could pop them open. I know that won't match your application.
Are you desoldering the eeprom to program it?
OK.. I am not sure how to do this. which pins do I check on the immobox? Keep in mind, I have 2 of everything on hand (ECM, MICU and Immo).
yes i did several times and MICU always failed! IMMObox and PCM always can sync but (D-3 no communication betwwen ECU and immobilizer) on immobilizer fault, funny thing is i can sync immobox and ecu successfully
