Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Immobilizer issues PLEASE HELP
Old 01-24-2021, 02:02 PM
ridinny's Avatar
Default Immobilizer issues PLEASE HELP
Good day to all.. I have a 2007 Civic LX w/ ~140k on it bone stock. Everything was fine until one day I went to start it and it stalled immediately. After doing some research, i figured out that I have an immobilizer issue. I had a somewhat weak battery, so I thought the car may have lost the program for the keys.
I used a Launch X-431 Throttle to reprogram the keys, but it tells me "Immobilizer System Is Not Normal" and "D-3 No Communication Between ECM/PCM And Immobilizer Unit".
I have checked every fuse, checked all connectors at the immobilizer MICU (fuse box) and ECM. All seem normal.
I really just want to bypass the immobilizer altogether and have been looking for wiring diagrams to figure it out, but I am not 100% confident I won't mess more things up. If anyone knows how to do this, PLEASE PM me with some guidance.
Otherwise, if there is a way I can test each piece individually so I don't have to replace them all, that info would be greatly appreciated.
TIA
Old 05-31-2021, 04:22 PM
kevinstone2010's Avatar
Default Re: Immobilizer issues PLEASE HELP
i have the same problem as yours, did you manage the problem?
Old 05-31-2021, 04:42 PM
ridinny's Avatar
Unfortunately.. it's still sitting in my garage. I found another 2007 Civic LX sedan in the junkyard. I got the ECU, MICU and the immobilizer. I used my Launch x431 to reprogram then all but I still get the same error code at the end.
Crazy thing is, I periodically just try to start it even though I haven't worked on it at all... And one day it started and ran. I drove it around a little. Shut it restarted it, drove it again. Next day, the problem was back.
Old 05-31-2021, 06:04 PM
i have ''D-3 No Communication Between ECM/PCM'' too but i can manage that by putting unregistered key and resulting to D1 but successfully sync the immobox and ecu you can try that method
Old 05-31-2021, 06:14 PM
ridinny's Avatar
Wow.. finally a response from someone that is actually having the same exact problem. So, I can get through the whole process right up until the end when I get D3. After that, I'm at a dead end. If I swap the immobilizer, I can start the process over until I got D3 again. Doesn't seem to matter which combination of pieces (ecu, micu, immobilizer) I have in. I've pinned out as many connections as I could figure out. I've gone through every troubleshooting step in the service manual. I've never had an automotive problem i couldn't figure out until this. I became so aggravated that it's just been sitting for 2 months.
Old 06-01-2021, 10:21 AM
Ryanthegreat1's Avatar
Are you both using the same scan tool? Can you get your hands on an alternate tool? Or check for software updates on your tool? I have an Autel that has successfully programmed many immobilizer keys in this generation.
Old 06-01-2021, 02:44 PM
yes we have the same scan tool LAUNCH x431 , we have no problem with the programming keys , our problem is immobilizer doesn't communicate with the ECU.
Old 06-01-2021, 06:06 PM
Maybe a suspect MICU. That sits between the immobilizer unit and the PCM on the S-NET communication line. This is the only communication line between immobilizer and PCM.
Are you able to try another car or another scan tool? It is very possible for the scan tool to have a bug in software on this specific generation of immobilizer.
Old 06-01-2021, 07:12 PM
ridinny's Avatar
I mentioned above that I've replaced (from same year and model car) and reprogrammed the ECM, MICU, and immobilizer. I've tried every combination of parts from both cars. If you read my post from yesterday, it comes up with D3 at the same point every time. It randomly started and ran one day even though I didn't change anything. Next day, back to the same problem.
Old 06-01-2021, 07:26 PM
MICUs were not real great around this time frame in all Hondas.
CR-V of this generation was notorious for failing MICUs.
Old 06-01-2021, 10:52 PM
Do you have a dump file for your MICU eeprom (93s56 eeprom inside micu fusebox) for comparing mine? my plan is to sync all the coding (ECU>MICU>IMMOBOX) so that they match altogether but i need file from other unit.
Old 06-01-2021, 11:31 PM
yes MICU is the problem but is the software not the hardware, starting with drain battery deletes immo coding inside the MICU and now scan tools cannot resync it, because eeprom data is corrupted and need to be replaced.
Old 06-02-2021, 05:31 AM
How did you arrive at that specific conclusion? This is an interesting topic to me.
Old 06-02-2021, 05:50 AM
ridinny's Avatar
ok.. first off THANK YOU for the response, but I have a few questions. , 1) how do i resolve the problem? I swapped the MICU already. 2) by what you're saying, this would occur whenever a battery goes dead or is replaced, no? 3) why did the car randomly start and drive one day?
Old 06-02-2021, 06:20 AM
we have to find a good working MICU eeprom file and reprogram it directly to our eeprom 93c56 chip inside the MICU, did you check the battery voltage of the immobox? mine has 11volts in it but my battery voltage around 12-13volts.
Old 06-02-2021, 06:24 AM
I have two MICUs that were known good, an 06 CR-V and a 12 Civic. I could pop them open. I know that won't match your application.
Are you desoldering the eeprom to program it?
Old 06-02-2021, 06:43 AM
ridinny's Avatar
OK.. I am not sure how to do this. which pins do I check on the immobox? Keep in mind, I have 2 of everything on hand (ECM, MICU and Immo).
yes , do you have eeprom programmer? eeprom chip inside is 93c56
Old 06-02-2021, 07:11 AM
Global Moderator
tech8's Avatar
This thread got very interesting.
Old 06-02-2021, 11:27 AM
I will have an eeprom programmer shortly. Looks like that 93c56 is in the soic-8 package? Any attempt to read that chip in circuit? Save some tear down steps.
Old 06-02-2021, 12:02 PM
With your scan tool have you attempted a Replace IMMO//MICU/PCM procedure? I recall seeing that on the Autel.
Old 06-02-2021, 12:10 PM
yes its a 93c56 soic-8 , desolder the chip, i read the chip and made a dump in it.
Old 06-02-2021, 03:10 PM
yes i did several times and MICU always failed! IMMObox and PCM always can sync but (D-3 no communication betwwen ECU and immobilizer) on immobilizer fault, funny thing is i can sync immobox and ecu successfully
Old 06-03-2021, 05:06 AM
ridinny's Avatar
Hey, did this actually resolve the problem?
Old 06-03-2021, 06:07 AM
That is still a work in progress.
Quick Reply: Immobilizer issues PLEASE HELP
