99 CRV - Power locks stopped working, looking for solutions
Hey I currently have a 99 CRV that has been having issues with the drivers side door wiring harness for a couple years. The power window wire broke late 2018 and I removed the door (which was a huge pain) to access the coupler and solder the wire. Unfortunately when I did that the speaker wire broke right at the coupler making it next to impossible for me to solder or crimp. I let it be but now my power locks have stopped working. I can't seem to find a power lock fuse on any diagrams but given the history of my harness and the fact that they are prone to failure I'm debating getting a new one. There are a couple of auto wreckers in my area I can check out but I would like to know if anyone could suggest some websites I might be able to buy a new one. Also any additional advice, suggestions or possible diagnoses are more than welcome. I'm not in a rush to fix this but its more a convenience things. I'm also going to be removing the door panel and checking the connector to the lock switch once the rain stops
Pulled the door panel today and checked the wires and connections. The wires and switch seem to be fine. Put a multi-meter on the wires and didn't register any voltage which leads me to believe that that problem is with the umbilical between the door and frame, the same place I had issues before.
Any additional thoughts or fixes before I begin searching for a new harness?
https://fusecheck.com/honda/honda-cr-v-1995-2001-fuse-diagram
https://fuse-box.info/honda/honda-cr-v-1995-2001-fuses/amp
does the rear glass opener work? Check the website link above and there's #25 under the dash and #10 under the hood .
Joey Mitchell
Apr 13, 2019 11:58 AM
Nisif
Nov 12, 2014 09:17 AM
