1992 Honda accord LX with a swapped H22A
Old Dec 30, 2020 | 01:41 PM
Dieselthebully's Avatar
Default 1992 Honda accord with a swapped H22A (NEED HELP WITH EXTRA ENGINE HARNESS PLUGS)
What’s up all this is my first post to the Honda tech forums I just received a 1992 Honda accord LX with a swapped h22a.
The motor was already dropped and was running 4 months prior.
they removed the air intake ,throttlebody ,fuel rail battery and a couple other odd little things .
everything is there the only thing that I’m noticing is there seems to be this small section of the wiring harness that is just a bunch of random plugs that have nothing to go on the passenger rear side of the motor.
I’m just wondering if anybody can help me out and let me know if it’s possible that those plugs have nothing to plug into because its a swap or was there something deleted or perhaps the harness need to be modified.
I received the project like this so can’t exactly say what was unplugged from where any help would be greatly appreciate it.
Old Dec 30, 2020 | 01:52 PM
99stockcivic's Avatar
Default Re: 1992 Honda accord LX with a swapped H22A
I presume you need the H22A harness, modify the Accord harness, or buy a conversion harness (I am also presuming this is a H22a1 engine) which means you should take a look here for some guidance:
https://importnut.net/h22a_swap.htm
This also has the distributor wiring.
Good luck.
Old Dec 30, 2020 | 02:47 PM
These are the plugs that I can’t find connections to and also the engine stamp
Old Dec 30, 2020 | 03:14 PM
Aradin's Avatar
Premium Member
Some or all of the plugs are probably for an automatic transmission if the car was previously automatic. It's common to do a 5 speed and H22 swap at the same time. If the car runs well then just tape them off so no moisture gets into them. You can depin and remove them from the harness if you're really worried about as well.
That's also not a 1992. It's a 94 or a 95.
Old Dec 30, 2020 | 03:35 PM
Awesome thank for the help!
Old Dec 30, 2020 | 03:54 PM
Welp that idea lasted 20 minutes lol, previous owner says it’s titled 5speed
( I can’t confirm until title comes in mail)
Old Dec 30, 2020 | 07:36 PM
Aradin's Avatar
Premium Member
They look like auto trans plugs to me. Especially the green square one.
Running the VIN might help.
Easy way to tell would be to look at the passenger side transmission mount. If the part that's welded to the car has been re-drilled before, it's been manual swapped. Other signs would be if your reverse light switch is wired separately from everything else, under the cowling on the driver's side there may be a random nut or bolt where the clutch pedal has been mounted, or inside the shifter area of the center console there will be a lot of modified wiring.
Old Dec 31, 2020 | 05:14 AM
So I’ve been told by the previous owner that just the motor was swapped the trans is original. So maybe they’re for an auto prelude trans?
Old Dec 31, 2020 | 08:36 AM
Ask which wiring harness was used, the original or the Prelude one.
Old Dec 31, 2020 | 10:22 AM
Also what anybody know what this wire would be it seems to have some blue heat shrink over the two wires
Old Dec 31, 2020 | 11:29 AM
So it looks like the one plug goes over to the top of the manifold the other two wires that don’t have clothes at the end of them I am almost certain that goes to the coolant temp sensor ,since there’s only two wires .
so now my main thing is just the greenplug and the plug with the blue loom also the plug coming off theHarness near the ABS relay and there seems to be one more plug right at the strut tower
Old Jan 1, 2021 | 03:48 PM
Aradin's Avatar
Premium Member
You will have to trace them and find out where they end up. That will give you an idea of what they're for.
tunerraceteam
Feb 22, 2009 03:49 PM
95 civic
Oct 3, 2003 10:58 AM
jinxster
May 30, 2003 11:46 AM
