quick Q about rocker shaft...
Old Nov 16, 2002 | 11:33 AM
baonest1's Avatar
Default quick Q about rocker shaft...
does it need to spin freely when its installed.. i found an imperfection in the P&P.. i beleive this might be a common one.
the shaftgoes in smoothly until i hit this "imperfection" then i have to push hard. its on the intake and exhaust both. would i need to have this thing sanded down. or is it ok cuz the shaft doesnt move.
thanx
[Modified by baonest, 3:34 PM 11/16/2002]
Old Nov 16, 2002 | 01:16 PM
rainmanEK's Avatar
big strong guy
Default Re: quick Q about rocker shaft... (baonest)
Looks like you should be ok, as long as the shaft will go through it! Whom did the P&P ?
good luck, eric
Old Nov 16, 2002 | 01:40 PM
baonest1's Avatar
Default Re: quick Q about rocker shaft... (rainmanEK)
alaniz tech did it...
when i slide it through.. it wont "spin"..
doesnt the rocker shaft have oil spouts or somthing. i oiled the rocker shaft and it made it easier to go in.
edit: think i may have answered my own Q. thats what the oil orfices (or whatever they are called) are used for. they line up with the hole on the shaft so the shaft doesnt move..
[Modified by baonest, 5:45 PM 11/16/2002]
Old Nov 17, 2002 | 12:14 AM
sgT's Avatar
sgT
rocker shaft is NOT supposed to spin
those holes just hold the shaft, doesnt have to be perfect
Old Nov 17, 2002 | 08:18 AM
baonest1's Avatar
Default Re: quick Q about rocker shaft... (sgT)
thanx guys.. i put my whole head together just to see how it looks.. looks good. i just need to check clearance on a couple of places.
Old Nov 17, 2002 | 07:24 PM
ITR#132's Avatar
Make sure you put the pins in that lock the rocker shaft from spinning. BTW, the pins are side specific.
Old Nov 17, 2002 | 07:51 PM
baonest1's Avatar
Default Re: quick Q about rocker shaft... (ITR#132)
yah, the oil orfices or whatever they are called.
Old Nov 17, 2002 | 09:06 PM
Bbasso's Avatar
could I see more pics of the head all done ?
thanks
Old Nov 18, 2002 | 05:23 AM
baonest1's Avatar
Default Re: quick Q about rocker shaft... (Bbasso)
thanks
yah, ill try to snap a few..
Old Nov 18, 2002 | 05:37 AM
Smitdog's Avatar
thanks yah, ill try to snap a few..
More pics =
Chenzo
Sep 30, 2014 04:13 PM
DagreenEK
Northwest (Sales)
Jan 2, 2009 07:47 PM
mixmastermatt
May 13, 2007 07:43 AM
biassj
May 16, 2003 03:57 AM
