Enlighten me on brake rotors
Old Nov 16, 2002 | 07:26 AM
ITR #0202's Avatar
Default Enlighten me on brake rotors
I am going to need to either get my rotors turned, or get new rotors... I was thinking that I may as well just get some Comptech cross drilled rotors, or some powerslot slotted rotors... What is anyone's experience with upgraded brakes? I don't wanna do a big brake kit yet... cuz I wanna do wheels and then get huge brakes.
Old Nov 16, 2002 | 07:48 AM
Ferrell's Avatar
Default Re: Enlighten me on brake rotors (ITR #0202)
autozone
Old Nov 16, 2002 | 07:53 AM
6ghatch's Avatar
Rotors are rotors, brake pads are going to make the difference. Autozone sells rotors for between $25-$30 each and that is all you really need. Then just choose a good brake pad for your driving needs.
Old Nov 16, 2002 | 07:57 AM
1GreyTeg's Avatar
Don't turn them, this weakens them more and makes them even more prone to warpage soon after.
Most everyone here will suggest you stay with the stock size and I must agree, a less expensive alternative to OEM rotors is a set of Brembo Blanks from Autozone, owners of these may list the part# because I'll need a set soon as well.
Cross drilled are designed for outgassing, cooling of rotors,
Slotted are for shedding pad dust, debris, and crud,
Neither are neccessary for the ITR as a daily driver, regular Autocrosser or occasional even track driver PDA or HPDE. You'll never punish the rotors enough with street applications to warrent these upgrades.
Autocross and Track may be different stories. Autocross still doesn't really warrent either rotor nor upgraded pads for that matter, the stock ITR brakes are simply Great.
As for occasional track or driving schools, then you may want to upgrade to race compound pads but even then you can still run stock, in the beginning as a novice until you get a feel for the car and begin to push it to it's limits.
The Stock brake rotors work absolutely awesomely with the proper pads as per the application. Depending on your level of experience and competition you may Not need to upgrade the brakes At All...
Don't waste money changing things that are nearly perfect to begin with.
IMHO of course, and if my comments need any correction or elaboration then feel free,,,
A.
Old Nov 16, 2002 | 08:34 AM
Bbasso's Avatar
Default Re: Enlighten me on brake rotors (1GreyTeg)
Anton I have to disagree, the statement "Don't turn them, this weakens them more and makes them even more prone to warpage soon after".
When I worked at a auto shop we used to get brand new rotors of all different brands and they were put on cars thinking that they should be good.
Well surprise to the the shop and I they needed to be cut.
OK here is my point sometimes brand new are not true and from all the rotors I have had to cut on my own cars in the past not one has ever warpped due to the resurfacing/cuttin/turnning, what does cause the warpping is the improper amount of TQ on the lug nuts or rather not appliying the same amount to all in the pattern which will prevent warps.
Old Nov 16, 2002 | 08:36 AM
Bbasso's Avatar
Default Re: Enlighten me on brake rotors (Bbasso)
OH, so my whole point is cut your rotors if needed and be sure to TQ them right.
Old Nov 16, 2002 | 08:47 AM
JDM nerbie's Avatar
New User
i always turn my rotor using an "on car brake lathe"
it give the rotors a true cut because you dont even need to take them off of the hub.
Old Nov 16, 2002 | 09:09 AM
1GreyTeg's Avatar
Hence the "Correct me if I'm wrong..."
I can understand turning them for true from the offset with new rotors and I won't disagree with you altogether but, from what I've learned, "no not just from the net," and again I could be totally wrong is just what I posted but, what I posted related to an already warped rotor in current use.
I have heard that after their being turned because of warpage that they are more prone to warping again. Especially under severe usage. I have also experienced this in one of my older Teg's, though I cannot confirm that they actually torqued the nuts after turning the rotors. What I can confrim is that the rotor's soon after became warped after about 2 weeks of regular commuting and spirited driving, "and No competitive drving."
Again hence the "IMHO"
I also do agree that Torquing the lugnuts to avoid uneven wear and future warping is Key. This is one of the FIRST things I learned soon after I started autocrossing with the boys.
Thanks Rob,
A.
Old Nov 16, 2002 | 09:14 AM
George H's Avatar
For people who auto-x or track their car, rotors definitely become a "fast-wearing" wear item. If you dont want to spend the money on honda parts, then the AutoZone route is the best for you.
Personally, I would enjoy the rotors 10 times more knowing I paid a lot less for them than I would have at the factory.
Old Nov 16, 2002 | 10:21 AM
ITR #0202's Avatar
Default Re: Enlighten me on brake rotors (JuJu)
Does anyone have a part number for the Autozone brake rotors?
Old Nov 16, 2002 | 10:25 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
I have an extra set right in front of me, part number #048731 3296 i believe. Legend SE front rotors.
[Modified by Rguy, 11:30 AM 11/16/2002]
Old Nov 16, 2002 | 10:31 AM
OBD-One-Kanobe's Avatar
New User
Default Re: Enlighten me on brake rotors (George Knighton)
I don't see any point in turning ITR rotors when new ones are $25 at Autozone and other places.
Yeah, How much $$$ is it to get a rotor turned? If it is more than $15, I may as well get a new one instead of having someone fix my tiny, warped GSR rear rotor.
Old Nov 16, 2002 | 10:46 AM
Bbasso's Avatar
let me just toss this up in the air and not directed at anyone.
IF you spend $50 on new rotors fine, you have new rotors and toss away metal that could be recycled. And could be un-true still- never will know with out cutting then on a machine.
Now if you took your rotors off and had them cut by a place it would only cost you $20 and now you have an extra $30 to spend on a nice lunch, also the difference of what is being shaved off your rotor is alot less then the 2 or 3 mm compared to buying legend/non-ITR rotors. Also you will know that your rotors are true.
Also no extra metal thats not being wasted.
just some thoughts, and are not aimed at anyone.
Old Nov 16, 2002 | 10:49 AM
Bbasso's Avatar
just for **** and giggles,
I have cut front rotors on my car for 11k miles and not one problem- also at limerock at 110+ speeds...
Old Nov 16, 2002 | 10:54 AM
ITR #0202's Avatar
I"ll probably just have these turned for now.
Old Nov 16, 2002 | 11:09 AM
Dave-ROR's Avatar
Anton: X-Drilled have a marginal cooling ability (read: basically nonexistant) over solid rotors.. and provide less thermal mass to dissipate heat from the pads.. pads will stay at higher temps and therefore shoot up to even higher temps, when it gets hot enough, they'll fade. (sooner than blanks of course).
Slotted? On a car that doesn't race on the dirt? why?
Old Nov 16, 2002 | 12:14 PM
Rob :190:'s Avatar
Default Re: Enlighten me on brake rotors (Dave-ROR)
:autozone:
Old Nov 16, 2002 | 12:31 PM
N0E5cape's Avatar
Default Re: Enlighten me on brake rotors (Rob :190:)
erm.. sorry if this is a stupid question
my brakes are squeaking like crazy lately, before they are warmed up. would changing the rotors fix this rather annoying problem?
Old Nov 16, 2002 | 12:47 PM
REDNECK TYPE-R's Avatar
Default Re: Enlighten me on brake rotors (N0E5cape)
STOCK PADS??
Old Nov 16, 2002 | 11:50 PM
N0E5cape's Avatar
Default Re: Enlighten me on brake rotors (REDNECK TYPE-R)
yea stock pads...
Old Nov 17, 2002 | 08:33 AM
Floyd's Avatar
I also don't see any point in fancy rotors, considering that the Honda Challenge was won this year on Autozone rotors.
LOL
"Autozone rotors: The race-proven choice of champions!"
We need to get Autozone to sponsor the ECHC.
Old Nov 17, 2002 | 08:50 AM
Bbasso's Avatar
hahaha, thats a different story George, IF they could be resurfaced I would do it but some of those pics Will puts up are just scary! and of course new would be better, but for the average smuck resurface is just fine.
dragonkx
13
Jun 29, 2010 07:37 AM
themikewoo
15
Oct 10, 2007 06:09 AM
standbackimapro
Sep 21, 2007 11:27 AM
toguemaster
May 15, 2006 01:39 PM
kbergeron
Aug 26, 2005 12:14 PM
