Help with my harmonic balancer. Is it okay to drive in this condition?
Old Oct 9, 2020 | 10:46 AM
Samvisal Sok's Avatar
Default Help with my harmonic balancer. Is it okay to drive in this condition?
https://photos.app.goo.gl/6GrSzu9NcvsX9oao7
https://photos.app.goo.gl/62H9N6vgzGtNPSfE9
Old Oct 9, 2020 | 11:42 AM
tonytiger44's Avatar
Default Re: Help with my harmonic balancer. Is it okay to drive in this condition?
what is the problem with the crank pulley? if the threads are messed up bring the bolt to auto zone advanced auto o'reiley's or a hardware store to find a tap to fix the threads and buy red thread lock so it stays tight i know when u turbo an engine on a honda its a known issue for the crank pulley bolt to loosen up.
Old Oct 9, 2020 | 12:13 PM
It just the woodruff key section. The teeth been chip off a bit. I want to see if it still drive able in that condition? The bolt is fine. I had to make a woodruff key to replace that broken one that was broken in half. When the pulley rotate at high rpm, will it come off because the chip area or just jb weld it so it stay when it rotate. I don't want to have another one where the belt came off again and timing be mess up.
Old Oct 9, 2020 | 12:33 PM
Ryanthegreat1's Avatar
Looks like the pulley is not fully seated. I don't recall the pulley overhanging the crank by that much.
Old Oct 9, 2020 | 01:56 PM
It suppose to be flush instead of it be pop out like that?
Old Oct 9, 2020 | 03:05 PM
Nearly flush. Needs a little bit of space for the bolt to clamp the pulley.
Old Oct 9, 2020 | 03:09 PM
I am looking for images. So far this is the best.
Old Oct 9, 2020 | 03:12 PM
Also make sure that bolt gets oiled and torqued correctly. The key is just for alignment, the clamping force of the bolt is what transmits the power.
Old Oct 9, 2020 | 06:29 PM
okay. Thanks for the information.You helped me understand a little more that i did not know.
