What spring for turbosmart ultragate 38 wastegate.
Old Sep 25, 2020 | 03:47 PM
93civiclsv's Avatar
Default What spring for turbosmart ultragate 38 wastegate.
Trying to get b16 turbo tune done but wastegate will not open before 10 psi boost cut. Ordered a 7psi turbosmart ultragate 38 wastegate and when i took apart i had two springs inside. 7psi inner(brown/purple) and a 7psi outer (brown/pink). Im thinking i just need one in there but not sure. Took around 30 psi to open the wastegate with both springs in it with car off. I used air compressor to make sure it wasent stuck shut.looking to run 7 psi and my car is not opening the wastegate before my 10 psi boost cut. Do i need to have both spings in or just one. And if just one should i use outter or inner. Thank you very much.
Sent from my iPhone
Old Sep 25, 2020 | 06:09 PM
TheShodan's Avatar
Moderator
Default Re: What spring for turbosmart ultragate 38 wastegate.
I wouldn't do that. the correlation between what the gate sees and where you're putting the air pressure is going to be different. Remember, these aren't like TiALs. The colors and numbering is different.
chunkybs
Apr 13, 2008 08:17 AM
akira712
Aug 8, 2006 09:46 PM
FRISBEE
Jan 17, 2005 09:48 PM
GSRswapandslow.
Jun 17, 2004 01:49 PM
ebp 99 si
Jun 15, 2003 07:45 PM
