Honda CR-V & Element 2WD & 4WD Element & CR-V
Chirping Noise After R&R of A/C Compressor
Old Sep 17, 2020 | 02:10 PM
Litzenbaum's Avatar
Default Chirping Noise After R&R of A/C Compressor
After reinstalling the A/C compressor (changed coil/clutch/pulley) I'm getting this new chirping noise when the engine is cold. The noise doesn't happen at first, but takes about a minute before it starts. Then, it goes away after a couple of minutes as it warms up. Turning on the A/C doesn't make a difference. Everything seems to be spinning fine. The mark for belt tensioner is right in the middle of the range. A/C clutch plate was torqued correctly. Not sure if it's a pulley or what. All the pulleys are: Power steering, A/C, water pump, alternator, belt tensioner idler, and crank. In lieu of a stethoscope, I used a section of heater hose to my ear and put the other end on the bodies of the power steering, alternator, and on face of the A/C clutch and didn't hear the noise coming specifically through the hose. I also tried to put the end of the hose on the nut for the tensioner pulley and didn't hear anything either. I was trying to do the same with the water pump when the noise went away, presumably because of warming up?
EDIT: If I spray water on the ribbed side of the belt, the chirping instantly goes away for a moment then comes back. Squirt water again and the noise goes away again.
Here's a short video so you can hear the sound. Sounds like crickets. Anybody have this happen to them before or know if there's a common cause?
Old Sep 17, 2020 | 07:00 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Chirping Noise After R&R of A/C Compressor
Try a new belt, which aren't very expensive. It may be due to the belt.
Old Sep 18, 2020 | 01:25 PM
tony_2018's Avatar
Fish Twig
Ensure proper adjustment as well.
Old Sep 18, 2020 | 06:15 PM
Litzenbaum's Avatar
Just replaced the belt and that did get rid of the chirping sound. The indicator arrow is very near the center of the acceptable range on the tensioner. Is the tensioner supposed to wiggle just a little bit with the engine running? It doesn't make any noise.
Old Sep 18, 2020 | 09:02 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
With the car idling, if the pointer on the auto-tensioner moves or fluctuates alot when the car is on; the auto-tensioner needs to be replaced. If the auto-tensioner made abnormal noises, it should also be replaced.
Old Sep 19, 2020 | 09:37 AM
Litzenbaum's Avatar
Here's a short video of the slight movement. I'm not sure if this is considered normal or not. I drew a black line on both sides of the tensioner to help with observing the movement. You can see the arrow is pointing just a bit off of the middle of the normal range. Again, this is with a new belt (which did make the chirping noise go away). I added more light about 11 seconds into the video, which makes it easier to see.
What do you think?
Old Sep 19, 2020 | 10:05 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
That is still okay.
Old Sep 19, 2020 | 10:14 AM
Litzenbaum's Avatar
That is still okay.
Great, thank you for responding.
jgoinfishin1
Feb 20, 2014 12:26 PM
raybo
Jul 8, 2012 11:14 AM
m_aster_y
Honda Civic (2001 - 2005)
11
May 22, 2011 02:23 PM
immajackuup
Jul 18, 2009 11:00 AM
dpkelly
20
Jun 8, 2007 05:38 AM
