Letting air out after intalling IAC valve?
So I have just installed a new IAC valve and i heard there will be air in the system, do i burp the air out of the system, if yes, is there a thermostat bleeder valve on d16y7? I could not find any.
No bleeder.
You do the inclined nose rad cap loose idle with heat set to max heat until rad fan kicks on 2 times bleed.
How do ya like dat run on sentence.
dannyly17
Jan 14, 2011 08:20 AM
