What is the part number or name for the steering rack lines?
Old Sep 5, 2020 | 04:33 PM
99stockcivic's Avatar
Default What is the part number or name for the steering rack lines?
Hello all,
1999 Honda Accord 2.3L 4 cylinder EX 4 door Sedan, automatic transmission.
I'm replacing the steering rack, it is shot. Got to the part where I tried to remove the lines from the rack, but even with good flare nut wrenchs, it still started stripping. Couldn't get them to budge. But as I was under there, I could see the lines didn't seem to be the in greatest shape anyway. So, I cut the lines, and have removed the steering rack. Here's where I need some assitance.
First, what is the "right" name for the two lines? I searched in Rockauto and Oreilly's, and I come up with power steering rack line, but only 1 line, the one that looks like it goes to the power steering pump on top. And...I notice not all of them look quite the same.
Two, what would be the part numbers for the two lines?
Trying to order, but really not wanting to take a chance without checking if someone knows the information, making it easier for me to get the right part the first time
Third, would someone have a diagram of the routing of the lines? I'm fumbling around a bit reaching, because I can see some of the bolts holding the lines, but I want to make sure I also follow it aliong to get all and them and put it back correctly.
Thanks for any assistance .
Old Sep 6, 2020 | 05:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: What is the part number or name for the steering rack lines?
https://www.hondaautomotiveparts.com...-s-hoses-pipes
Hose, Feed
53713-S84-A04
Pipe A, Return (10MM)
53720-S84-A01
Old Sep 6, 2020 | 05:49 PM
You are AWESOME!
Parts ordered!
Thank you!
I don't know why I was having so much trouble.
EFing_Slow
Jun 4, 2017 01:10 PM
kirkland08
Jan 25, 2011 10:43 AM
SpOoNisMyFriEnD
10
Apr 1, 2005 06:53 AM
limey bastard
Apr 24, 2004 12:52 PM
