Really rough idle, low power and doesn't rev over 3k
Old Aug 18, 2020 | 12:02 PM
USA's Avatar
USA
Default Really rough idle, low power and doesn't rev over 3k
I have a 98 ls Integra with a gsr swap, I started the car leaving work and it sounded a little rough but it usually does at first, however the problem never went away. When I got out on the road it kinda stalled a little and had like 60hp and wouldnt rev over 3000 in any gear it was like a weird soft limiter. I checked the oil and put in a little, not the issue. I changed from my chipped obd1pobd1 ECU to the "stock" obd2 p72, nothing changed. There are no codes being thrown I'm at a loss here any ideas?
Old Aug 18, 2020 | 02:14 PM
USA's Avatar
USA
Default Edit: Really rough idle, low power and doesn't rev over 3k
The car also does this weird thing when you try to start it where all power will shut off for a split second, not like when you engage it for the first time but midway through the starter running
Old Aug 18, 2020 | 08:08 PM
EWY's Avatar
EWY
Default Re: Really rough idle, low power and doesn't rev over 3k
Double check your grounds.
Old Aug 19, 2020 | 05:37 AM
USA's Avatar
USA
Yeah the guy I bought it from put the battery in the back and he only put the negative to the chassis in the trunk, do I need to run a negative all the way to the engine bay?
Old Aug 20, 2020 | 07:52 AM
USA's Avatar
USA
Checked every ground on the engine they're all fine, tried starting it again and blew the 250 amp fuse coming out of the battery
Old Aug 20, 2020 | 01:05 PM
Relic1's Avatar
sounds like you have a short in the positive battery relocation cable somewhere.
Old Aug 23, 2020 | 03:42 AM
USA's Avatar
USA
Alright so I got it fixed, turns out either something fell into the timing cover or the crank pos sensor bolt backed out. The CPS was in two pieces and even broke a tooth on the sensor wheel. The timing belt was holding on for dear life and slipped a couple of teeth. Luckily I didn't hit a valve and she's back up and running.
mokkema
May 24, 2009 03:28 PM
lsturbo*
May 21, 2008 01:48 PM
JasonST
Jul 11, 2006 09:42 PM
JDM_Andrew
Jan 27, 2006 11:44 AM
return_2020
Aug 12, 2005 07:44 AM
