Engine Timing
Old Aug 18, 2020 | 01:04 AM
coachroy's Avatar
Default Engine Timing
I've got a B16A2 engine. Is it possible to have the TDC index mark on the crankshaft gear that the timing belt goes around line up differently than the pulley that has the single line to show TDC? I want to say no since they are aligned with the woodruff key. just want to make sure.
Old Aug 18, 2020 | 09:14 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Engine Timing
I've seen them not align if the keyway in the crank is damaged or if the woodruff key is missing or the wrong size. Otherwise, they should be in line.
Old Aug 18, 2020 | 04:07 PM
muellersfan's Avatar
If you fail to position and maintain the cams and crank perfectly at TDC1 before installing the timing belt, you will have a very bad day.
Attention to detail is everything when installing a timing belt.
Old Aug 18, 2020 | 04:11 PM
coachroy's Avatar
Well here's what happened. I replaced the front main crankshaft seal. When I put it back together I looked at the mark and lined it up and then placed the pulleys back on and slipped the belt over the camshaft gears. After I did that, I saw that my TDC mark on my pulley was off a bit. When I turned it back to line up, my cam gears were off one tooth. The intake cam gear lines up nicely but the exhaust did not. So I assumed that side must have rotated slightly when I put the belt on. I removed the belt, rotated the gear to line up and then put the belt back on. Everything runs great now. I was just concerned if for whatever reason the Pulley TDC and Crankshaft gear TDC would be different some how if everything was installed correctly.
Old Aug 19, 2020 | 02:54 PM
egsleepercivic's Avatar
here you go
another eg
Sep 9, 2015 02:04 PM
Justephen Sae
Feb 1, 2015 08:20 AM
heeltoehonda
Nov 2, 2009 10:56 AM
Rostr02
Aug 11, 2005 06:19 PM
bluedelsol
Feb 23, 2004 02:49 PM
