97 honda civic motor swap
Old Aug 13, 2020 | 06:42 PM
ashley mitchell's Avatar
Default 97 honda civic motor swap
I have a 97 honda civic lx 5 speed motor locked up and am curious if a motor from a 98 will bolt up with no issues
Old Aug 13, 2020 | 07:09 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: 97 honda civic motor swap
Yes the USDM long blocks are the same.
Old Sep 28, 2020 | 05:50 PM
kyle holden's Avatar
Hi i have a similar question. I have a 97 vtec lx 5 speed the motor blew so i had a 2000 non vtec auto motor to use to replace mine i swapped over everything off of mine onto to 2000 motor . ( trans, intake mani, exhaust headers, distributor, alternator, stater, ) u get the picture i swapped everything from mine to the 2000 block i didnt put my vtec heads on right away i ran it non vtec for bout a week. I finally put my vtec heads on and upon starting it the idle was horriable and wouldnt stay running unless i had my foot on the pedel. So after cleaning my iacv replacing my plugs rotor and knock and o2 sensors it fianlly stays running but the idel is still very rough and the car is running like crap pls someone help in out of ideas and rdy to junk the car!
Old Sep 29, 2020 | 10:23 AM
Spaceturtle917's Avatar
Sounds like your ignition timing is bad, has happened to me a few times after a head swap for obvious reasons. Also, make sure your timing belt is in time.
I'm certain it's ignition timing. Get in there with the timing light.
https://honda-tech.com/how-tos/a/hon...-timing-374867
Old Sep 29, 2020 | 11:49 PM
well spaceturtle917 theres no need to do any timing work or anything besides swap out another motor yet agin cus today while driving the car suddenly shut off and wouldnt start back up so i was gonna do the timing once i took my valve cover off i noticed a milky film ( water in my oil) so i procceded to take everything off to check out my head gasket thinking maybe it moved when putting it on before well needless to say i need a new motor yet again im including some pics so u guys can see what happened and ill include some of the first motor that blew up also
This is what happened today
Today
The first motor that blew up nice huh i really mess things up when they get messed up lol
First motor
First motor
First motor now mind thats the bottom of my block
ThatCivicKid
Sep 8, 2017 11:33 AM
NcDurk
15
May 30, 2016 04:17 PM
Warpedtoys
Jun 19, 2010 10:43 PM
jdm_soya
Dec 6, 2009 01:12 AM
Frost7177
May 23, 2007 11:44 PM
