well... start up for the new build was "supposed" to be Tuesday *looks at calendar, puts head down* alright so here's the build sheet. Css b18c5 bottom end, 81.5mm wiseco pistons, eagle rods, gsr head, obd1 p28, coil on plug setup, 380 lph fuel pump 2200 bosch injectors.
this is the initial start up and I can't get it to do so. Car does get fuel and cranks. I'm sure these plugs are fouled out due to it
2668 spark plugs. I just grabbed a new set to help assist me but so far I'm not getting spark?? Checked fuses under dash and none are blown, ecu light blinks when i turn the key, battery is good car does crank just no start i tried a "metal to spark plug" trick and didn't see a thing from the plug spark wise. I do have a test light and I have some time .. well no I don't but yea any guidance will be nice. Also ignition timing and dizzy positioning have not been done but I dont have a timing light. Any help would be greatly appreciated. Thanks for reading, send help plz lol
