Random misfire on all four cylinders
Old Aug 5, 2020 | 10:16 PM
nnneyr's Avatar
Default Random misfire on all four cylinders
I have a 2001 Honda prelude that has a Robson misfire on all four cylinders and idle bounces when it’s cold, not sure of they are related but I’d rather say more then less, I have checked so many things to try and fix this, icm, plug wires, spark plugs, cap and rotor, iacv, fuel filter, timing belt/water pump, tdc and cps sensors, egr valve, knock sensor, and many more things have been replaced, I have taken it to a shop before and they couldn’t find a vacuum leak (they may have missed they aren’t the brightest there) the only weird thing is when I take out my stock ecu and put a pherbnet ecu that was tuned from another prelude the misfire is gone, he ran that without an egr valve, so my mind can only think of air fuel problems but I can’t find a single thing, so I am requesting help to find this issue, it mainly misfires when under acceleration
Old Aug 6, 2020 | 11:44 AM
snobordboy's Avatar
Moderator
Default Re: Random misfire on all four cylinders
Fuel pump? injectors? EGR valve bad or EGR ports clogged?
Old Aug 6, 2020 | 02:23 PM
nnneyr's Avatar
egr valve is brand new and I haven’t cleaned the ports
Thateguhate
May 19, 2011 08:04 AM
Bowl_of_Rice
Feb 6, 2011 06:56 AM
S2k Hybrid
12
Apr 24, 2007 09:41 PM
jumpman83
Oct 12, 2005 11:20 AM
H0ndaJunkie
Aug 23, 2005 09:01 PM
