Vtech rpm drip
Old Aug 2, 2020 | 02:18 PM
Jeremy64's Avatar
Default Vtech rpm drip
I have a 96 accord ex automatic when i hit 4000 it drops to 3700 then goes like vtec or at least sounds like it. Have replaced timing belt wich has been done by another. My odometer reads 113??? But i know it is not correct also they where one tooth different then my timing count on belt. my just wanted to know if it normal. I have not removed the vtec to check the screen i have a new gasket coming and will wait. Any one have similar issues?? Or may not be an issue just normal
Old Aug 5, 2020 | 02:41 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Vtech rpm drip
VTEC on the B1 does not 'kicked in'. It's much more linear and does not have an rpm switch, it can be activated very low, it's dependent on engine load as well as rpm.
If your oil pressure switch is leaking it may give an erratic signal and cause VTEC solenoid to drop off momentarily, as well as a clogged screen.
Low oil can do the same.
Verify no oil leaks and full sump.
If you are not used to the Honda F series engines it can be easy to be one tooth off.
Old Aug 9, 2020 | 08:24 PM
Jeremy64's Avatar
so i got my new screen/gasket my old one was clean my oil is normal i also have no engine codes, checked with scanner with live data. May not be an issue I usually do not peddle to the metal i will manually shift my auto from time to time. Well after i reassembled i took my car back out. Found it to be normal for my driving little throttle it backs off 2-300 rpm when vtec starts but if i mash the peddle no drop in rpm at 4000 or so when manually shifting. Thanks mad mike.
Loy
Apr 14, 2014 05:57 PM
MindEddy
Nov 6, 2013 05:36 PM
along2285
Aug 7, 2012 11:43 AM
01celica_gts
Aug 17, 2006 08:31 AM
Zulu888
Sep 30, 2003 05:57 PM
