Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 Accord SE V6 AC Compressor Problem
Old Jul 29, 2020 | 04:56 PM
kvalrico's Avatar
Default 2007 Accord SE V6 AC Compressor Problem
Hi All,
The AC compressor clutch isn’t engaging. I swapped out the compressor clutch relay with several other relays without success, so I don’t think it’s the relay. The MG Clutch fuse is good, so it isn’t that. I also checked the "AC" fuse in the interior fuse box on the drivers side, all good there. I start the car, turn on the AC to check for power but not getting anything. I’m not 100% sure I’m checking it correctly with my multi-meter. I touch the meter probe to the pin on the electrical connector but it’s not showing any DC voltage, just 0.00.
A little back history, a year ago it stopped cooling, took it to the garage and they charged it up and said there is a leak. It worked fine until recently. Now the compressor doesn’t engage when you press the AC button and no air. I bought a can of refrigerant, AC Pro I think? Tried last night to recharge it. Hooked up the hose to the Low side and the gauge on the can read “Low”. Turned on the car to try and put more coolant but again the compressor never engaged and after a quick pull of the trigger on the refrigerant can, it said the system was “full”. I find that hard to believe. Guessing it just filled the line super quick but without the compressor running it’s a false reading.
So trying to figure this out. Is the compressor not running because the pressure level is too low? Or is the compressor not running because it’s shot and time to replace it? Or, am I not getting power to the compressor? Is there another fuse to check that I’m missing? I couldn’t find one other than the relays and MG Clutch fuse. Can you confirm how to test for power with my meter? Trying to fix it myself. Can’t afford the garage and it’s too hot in Florida in the summer to be without ac.
I checked for pressure last night by pressing on the Schrader valve but nothing came out. That’s when I tried to recharge as mentioned above. Can the clutch go bad but the rest of the compressor is still good? Open to all input, would really like to get the AC working again. Thanks, Chuck
Old Jun 24, 2022 | 06:05 PM
Johnoolo's Avatar
Default Re: 2007 Accord SE V6 AC Compressor Problem
Did you ever solve your problem, this sounds Erie familiar to mine.
Old Jun 28, 2022 | 10:10 AM
kvalrico's Avatar
I ended up installing a new compressor and it's worked great since April 2020. I also installed all new O rings in the AC system since it was leaking coolant and the system has been tight since. AC is working great and blowing ice cold. I wasn't able to determine exactly why the compressor wasn't working, but since the new compressor works it wasn't a power problem. Suspect the internals were shot or it was the clutch.
pro1911
Jun 29, 2024 09:52 AM
ewgoforth
Sep 9, 2014 07:13 AM
saikou
Aug 9, 2011 08:22 PM
drpapijr196
Jun 15, 2011 02:17 PM
imjustagirl
Aug 19, 2007 08:54 PM
