Need you guys help/suggestions...
98 civic ex rear brakes is kicking my butt.
ive been struggling to bleed the rear brakes and every time i pump the brakes the wheel cylinder piston would pop out and wont go back in.
Ive put new wheel cylinders on both side with new hardware...also i replaced the passenger ebrake cable but it seems like its about a 1/2" shorter...but i adjusted the cable by the ebrake handle.
Ill put the old ebrake cable back on as i was able to break it free...it was stuck/siezed before.
Im pretty sure i put everything back together correctly as i took some pics of old brakes before i took it apart.
Any help/suggestions would greatly be appreciated.
Pics of what it look like after everything put back together
