9 inch fans for cooling
Old Jul 7, 2020 | 02:47 PM
90lsvcrxva's Avatar
Default 9 inch fans for cooling
So I know cooling is always a issue with boosting civics and integeras. My last set up ran hot. So o went with a CSF King Cooler this time with spal 9 inch fan. Hoping this is enough with the intercooler blocking most of the airflow to the radiator. Anyone else running a similar setup? Did you have to change the fan? If so can I swap the 12volt fan for a 24volt? Looks like Spal makes a 24 volt and it pushes a lot more cfu. Any help or ideas would be helpful!
Old Jul 9, 2020 | 08:31 AM
AZ_CIVIC's Avatar
Default Re: 9 inch fans for cooling
I actually bought the same radiator kit you have, but I didn't even bother using the spal fan it came with but purchased the beefier 9inch span fan that pushes I think 200-300 more CFM.
I am also running the radiator setup underneath the car at the rear but haven't got to test it out yet.
f22a1 ftw
Aug 7, 2010 04:57 PM
Obama
Mar 2, 2010 05:33 AM
91EF919
Apr 4, 2009 12:12 PM
platinum00
Jul 30, 2006 07:55 AM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
