p72 s300 v3 NA b16a innovative MTX-AL wideband sensor
Old Jul 4, 2020 | 08:18 AM
sh1ntaox's Avatar
10 Year Member
Default p72 s300 v3 NA b16a innovative MTX-AL wideband sensor
I have read up on as much of this topic as i can find and have seen that it varies with setup choice to some extent. i haven't seen any info on this specific setup and am confused which way to go. 1989 civic si ED7 running a first generation b16A naturally aspirated on a p72 with s300 v3. the wiring harness is Rywire obd0 to obd1 as well the bSeries harness. it is running on a basemap for the break in period and is showing no check engine light running the stock o2 sensor. i have another bung welded on and was aiming to hook up the innovative wideband and run as well. based on what i have read from multiple different sources i am pretty confused which pins should be tapped to make this function. innovative MTX-AL is the sensor kit its the BOSCH LSU49 sensor. initially i was looking to just run the wideband sensor in place of the stock o2 sensor and just keep a single bung but wasn't into the idea of trimming resistors to get the full voltage out of pins. this is why i was trying to have both running. is it possible and safe to run both the stock o2 sensor and the wideband sensor on a separate bung simultaneously ? with this specific setup what are the best pin choices to tap?
Wildemanam
Honda CR-V & Element
Jan 30, 2018 08:58 AM
96vtecI4
Aug 12, 2007 12:33 PM
Nisif
Mar 16, 2005 08:53 PM
tonylude94
Aug 21, 2003 01:26 PM
