Ok so I can not get this window to stay on track.what it does is if you till it down the front goes down first throwing it off track. If I put a lil pressure on the back of the window than no problems.
things I have done so far.
Replaced the regulator as old one was bad.
Changed the runner as it was bad.
Lubed the hell out of it with silicone.
Adjusted bolts so many times.
The diagrams below show the proper way to adjust the door glass for your Civic coupe.
If after adjusting the glass, the problem persists, then check the new regulator joint that I circled in the last two diagram. It's possible that this joint was damaged (loosened at rivet) because the glass was not adjusted after installing the new regulator.
