D15B Turbo Crome Tuned
Old Jun 25, 2020 | 07:44 AM
Dropy92's Avatar
Default D15B Turbo Crome Tuned
Hello there. My brother just made a D15B Turbo setup I tuned in Crome. Its Stock internals D15B Engine with D16Y8 head with Vtec. 320cc injectors from Prelude and T25 turbo from nissan Silvia. 3"intake 2.5" exhaust with bigger cat.
I used to tune Crome Pro, AEM wideband gauge with LSU 4.9 and Phormula KS3 knock sensor.
I would like to show you maps I ended with. We also have EGT gauge. We would like to stay under 900°C wich was hard to be with 12.6 AFR so we was forced to go 10.6 AFR to stay at low EGT.
What do you think about? At 6000rpm and 8Psi we are at 12°ignition and EGT is still pretty much high (930°C). Compression ratio could be around 10:1. (by ferrea valves)
Spart plugs are at stock distance 1.1mm (0,044inch) and everything more than 12° ignition make Knock sensor to jell like detonations. We are actualy at 174HP and 200Nm. Measured by G-Tech RR.
I think we should be able to make more from 8Psi. Should not?
Last edited by Dropy92; Jun 28, 2020 at 08:08 AM. Reason: New Shining Golden Pipes
Old Jun 25, 2020 | 08:27 AM
Nathan937's Avatar
Default Re: D15B Turbo Crome Tuned
Are you running out of fuel on this? Those injectors seem pretty small. What duty cycle are you hitting near read line to keep it at 10s afr
Old Jun 25, 2020 | 08:52 AM
Dropy92's Avatar
It is actualy pretty high over 100%.
Old Jun 25, 2020 | 08:55 AM
Nathan937's Avatar
I would start with larger injectors and get those back under the “safe” level of 85% max
Old Jun 25, 2020 | 09:17 AM
Dropy92's Avatar
And except the injector duty cycle. Could the wide gap of spark plug make misfire which would be detected by knock sensor like detonation?
Old Jun 25, 2020 | 10:56 AM
Nathan937's Avatar
It’s plausible. What octane fuel are you using?
Old Jun 25, 2020 | 11:38 AM
Dropy92's Avatar
Natural 95
Old Jun 25, 2020 | 10:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes. Also, ignition timing being too retarded will cause excessive EGT values, so add some timing to see if your EGT's go down and the knock goes away. Gap the plugs down to .030" or .75mm.
Roy Leyva
Engine Management and Tuning
Aug 30, 2016 02:14 PM
crxb16a90
Nov 9, 2009 07:12 AM
B18EG6
Dec 13, 2006 03:37 AM
MarkAngelo
Sep 20, 2004 07:35 AM
MachAF
Jun 21, 2003 06:02 AM
