Help? D15Y8 PCV
Old Jun 21, 2020 | 11:12 AM
tandemzzz's Avatar
Default Help? D15Y8 PCV
Im working on getting my girlfriends EG8 with a D15b7 swap. It had a Y8 manifold and a B18 tb. Im installing the charcoal canister and I believe theres supposed to be a hose that connects to the tb/manifold but there is no port for it. Any suggestions?
Photo below for reference
Old Jun 21, 2020 | 12:47 PM
muellersfan's Avatar
Default Re: Help? D15Y8 PCV
Old Jun 21, 2020 | 01:53 PM
tandemzzz's Avatar
Originally Posted by muellersfan
only issue is, it has a b18 throttle body which doesnt appear to have the pcv nipple
Old Jun 21, 2020 | 03:07 PM
Those nipples are present on the Y8 IM rather than the TB.
Old Jun 21, 2020 | 08:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Either use an OLDER throttle body that has the evap port at the 12 o'clock provision or consider drilling out the hole that you have and make a small port through the T/B to connect your pictured hose as if you had an older style throttle body.
Iloveyourhonda92
Mar 25, 2010 01:39 PM
RACEPAK
11
May 31, 2005 09:34 AM
EJ2-Fluffy
Jan 18, 2005 04:33 PM
hondaciv3
10
Sep 14, 2004 06:38 AM
JCracer723
Jul 29, 2003 10:06 AM
