Problems converting to OBD1
Old Nov 15, 2002 | 04:35 PM
Nameless RB26's Avatar
Default Problems converting to OBD1
I plugged in Kenji's chipped P28, and his conversion harness today.
00 JDM ITR, 2000 Si harness
I knew it was going to throw a code or two because of the vtec pressure switch, but the problem is we can't even pull codes from it. The CEL is on!
The idle fluctuates for about 15 seconds (up, down, up, down, up, down) then it will calm to about 1300. It does this everytime I let it go to an idle.
My questions are:
-Would not having a vtec pressure switch be causing all this?
-Is there an OBD1 component that I need to include somewhere when converting OBD2 - OBD1?
I wasn't getting any CEL's before when I was running the CTR ecu.
HELP! thanks
Old Nov 15, 2002 | 06:22 PM
Default Re: Problems converting to OBD1 (Nameless)
ttt
Old Nov 15, 2002 | 06:32 PM
98cwitr's Avatar
'00 si is obd-2...p28 is obd-1 have to have a obd-1 harness for a obd-1 ECU. I could be wrong on this
Old Nov 15, 2002 | 06:44 PM
CivicEK.PDX's Avatar
OBD1 vehicles have thaat thing under the TB. Maybe that is it?
Old Nov 15, 2002 | 07:53 PM
vtec.dc2's Avatar
what kind of car do you have? is that an engine swap w/ JDM ITR Engine? I thought jdm are not obd2
http://hondata.com/techecuid.html has some information there
Old Nov 15, 2002 | 07:58 PM
TypeR76's Avatar
Default Re: Problems converting to OBD1 (vtec.dc2)
Try this. Unplug your EVAP purge solenoid near the firewall.
Old Nov 15, 2002 | 08:05 PM
Default Re: Problems converting to OBD1 (TypeR76)
Yes, I have a conversion harness. (of course!)
Anyways, I fixed the idle problem. I put a piece of duct tape over this hole, for the time being:
I also checked the code, which is 22. I believe it has something to do with the vtec pressure switch, since I don't have that yet.
Old Nov 15, 2002 | 08:09 PM
rainmanEK's Avatar
big strong guy
You need to also remeber that this is more of a racing ecu, Not designed for emissions or Perfect drivabilty! This ecu is designed to make power!
have fun! eric
Old Nov 15, 2002 | 08:12 PM
Default Re: Problems converting to OBD1 (rainmanEK)
have fun! eric
gotcha! I'm just glad I didn't have any problems with kenji's stuff.
Kenji is the man!
Old Nov 15, 2002 | 09:08 PM
Cosworth's Avatar
Kenji's products rock!
What's more, his service is the best, period.
Old Nov 16, 2002 | 01:26 PM
kenji's Avatar
25 Year Member
Default Re: Problems converting to OBD1 (Cosworth)
Thanks for the compliments guys.
If you have any more questions feel free to ask me. Thanks.
-kenji
sevenfc
Apr 22, 2009 08:02 PM
donut.
Feb 15, 2007 12:29 PM
Type RS
Nov 18, 2002 10:09 PM
gsrhatch530
Sep 21, 2002 03:11 PM
