Team Loyalty has a B20VTEC build Question that needs your input.
I’m going to b20v build and I need some answers please.i got a b20 block hone to 84:5. I got type r rep piston with stock b20 rods and rod bolts . With a gsr head . Will the the piston hit the head or valves ? And do I need to resurface the crank if the old block was good and which size bearing I need ? And if I get super tech spring and retailer for the head what valve shoukd I get I seen super tech have flat one and other one which one good to get ?
Will the the piston hit the head or valves ? It will not hit the head, whether it hits the valves depends on your cams
And do I need to resurface the crank if the old block was good and which size bearing I need ? Yes get the crank resurfaced, and usually OEM bearings are best, your engine builder will tell you what colors to run
And if I get super tech spring and retailer for the head what valve shoukd I get I seen super tech have flat one and other one which one good to get ? Flat valves add a small amount of compression, i usually recommend people stay with OEM size and shape unless they know what they are doing
lakaspeed
12
Apr 14, 2012 12:56 PM
