b20 vtec motor damaged! what should i do???
Old 04-12-2012, 10:18 AM
lakaspeed's Avatar
Default b20 vtec motor damaged by BLOX TB.... what should i do???
my b20vtec motor start knocking so i removed the engine to check it first check the rod bearings thers is no sign of wear even on main bearing
so i removed the head and found a allen head screw stuck on my head and also made some marks on my piston cylinder #1
found out the screw came off my BLOX THROTTLE BODY from the thrrottle plate
the allen head screw still on my head
my set up
gsr head
blox hsl 3 cams
blox cam gears
blox valve spring n retainers
victor x manifold
72mm BLOX TB
b20 block
84mm rs pistons
stock rods with arp rod bolts
micropolish crank
acl race bearings
b16 tranny
comp clutch
light flywheel
Old 04-12-2012, 10:24 AM
Hatorade's Avatar
Default Re: b20 vtec motor damaged! what should i do???
Old 04-12-2012, 10:32 AM
b20vtech's Avatar
Originally Posted by Hatorade
Is this guy Mexican or Hawaiian?
Old 04-12-2012, 10:40 AM
morbius18's Avatar
That sucks. I'd take it to a machine shop and have them look at it. The head should be a pretty easy fix for them. The piston might also be ok. I'd go find someone who works for Blox and give them a swift kick in the jimmy
Old 04-12-2012, 10:42 AM
Hatorade's Avatar
he's Chinese
Old 04-12-2012, 03:08 PM
ahhwhat?'s Avatar
Ouch!
time to go Big
Old 04-12-2012, 04:20 PM
FishaCrx's Avatar
Blox!
Old 04-12-2012, 04:34 PM
raverx3m's Avatar
blox must not used treadlox.
Old 04-12-2012, 05:24 PM
mike703's Avatar
^^^^ this is probably true. next time you should do what i do to every single screw on my butterflies and throttle body. i jb weld those things call me crazy but yes i am paranoid and have never had an issue.
Old 04-12-2012, 05:27 PM
Runnerdown's Avatar
Mediocre aftermarket parts failing and causing damage? No way?!
Time to rebuild the right way, half *** it and you will likely regret it
Old 04-12-2012, 05:49 PM
m_shake's Avatar
Blox makes there own knock off of loctite called loxtite, guess the quality is lacking..
Old 04-14-2012, 08:12 AM
bks84's Avatar
Not to disagree, but a local had the same situation with a Holley TB. Caused a lot more damage though.
Old 04-14-2012, 12:56 PM
Retired Moderator
EsotericImage's Avatar
time for me to pull off my intake and look at my butterfly bolts
I wish i lived in cali and toss all theyre shitty products ive had to replace thru their window during the blox car meet.
aallen2079
02-22-2010 05:57 PM
reithhikaru
02-12-2008 02:32 PM
916jDmDc2
08-12-2007 05:05 AM
84DA69
11-24-2006 02:05 PM
no_boost
11-30-2005 01:59 AM
Quick Reply: b20 vtec motor damaged! what should i do???
