HELP My Civic 96
Old Jun 10, 2020 | 07:29 PM
DTurboSingle's Avatar
Default HELP My Civic 96
A question, I have a problem with my car, what happens is that when I walk below 6000 rpm the car pulls well, it only goes beyond 6000 rpm, which is when the vtec is activated and starts to throw explosions and no longer move on ... It moved over time and improved a bit a few days, the intake and sensors pull well. I have 50 lbs on the gas regulator and 10 lbs to the turbo with all stock, the car was pulling perfectly days ago
Someone who had the same thing happen and how they solved it..?
Old Jun 11, 2020 | 08:53 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: HELP My Civic 96
What fuel are you running?
What brand/model spark plugs are you running and what are your spark plug gaps set to?
Have you tried a new set of spark plugs?
Old Jun 11, 2020 | 02:09 PM
Gasoline, brand of the spark plugs is ngk iridium, and I will hardly buy some ngk bkr7
Old Jun 11, 2020 | 04:36 PM
DaX's Avatar
DaX
Loved
Community Favorite
What is your spark plug gap? If you run too large of a gap it can blow the spark out. I am running 0.020 inch (0.50 mm).
Old Jun 11, 2020 | 04:51 PM
Is 0.030
Old Jun 11, 2020 | 04:59 PM
DaX's Avatar
DaX
Loved
Community Favorite
Tighten that gap up and try again.
Old Jun 11, 2020 | 06:31 PM
wunfstgsr's Avatar
Loved
Community Favorite
What engine management/ ECU are you using? do you have any check engine lights?
Try to reset the ECU just unplug the battery for a few mins and plug it back in.
Old Jun 12, 2020 | 01:48 AM
Nathan937's Avatar
You could try tightening up that gap, although I don’t feel to confident about it. It would at least rule it out. At 10lbs anyways I’d imagine that that should be sufficient. As I run my car at .025.
Im curious as to what EMS are you using? And do you have the ability to read data and data log? I’d do a run and get it acting up while your recording, and go back and see if any errors are coming up or any sensor is going Haywire while in vtec. Or even a timing/vtec engagement issue itself.
Old Jun 12, 2020 | 01:33 PM
I have managed to fix my problem, it was the spark plugs, my engine had hot plugs which are "ngk iridium" and I put some "ngk bkr7" plugs cold and my problem was solved both are at 0.030Thank you very much for commenting and helping
Old Jun 14, 2020 | 07:43 PM
NVturbo's Avatar
O.G. triple O.G.
RE-GAP the plugs to .020 and you will notice a difference.
el negro
49
May 30, 2006 07:25 PM
