2000 Civic Si LS Vtec component identification help
Old Jun 1, 2020 | 01:27 PM
ERA_Evil's Avatar
Default 2000 Civic Si LS Vtec component identification help
So I bought a built 2000 Si with an LS Vtec, it seems they ran a turbo since it no longer has the A/C and I'm guessing they blew the original B16A2 block and built it as an LS Vtec. It has the stock ECU, but I already got a P28, i just want to get the tune but since the motor was already built I dont know exactly what parts were used.
I need help/guidance on trying to ID as much parts with as little teardown of the engine as possible.
i.e. stroke, pistons, etc so that I can get the info for a tune. For example i have seen some pistons with marking on the top, say PR3, so i was thinking a boroscope through the spark plug hole, or say removing the oil pan to try and ID the crank and pistons for example.
Any ideas? And as well what should I look for? I couldnt find any safe way to ID the crank aside from measuring, but i dont have any reference info to know from what car it came.
I do know it is a B18B1 from a 1994 Integra, by the block code, it is a PR3 head, i'm assuming the original one from the car's B16A2, everything else as far as I know is stock, save for bolt ons (i/h/e) .
What markings or measurments should I look for on the crank/rods/pistons? So that i can properly ID them to know the info on the engine and know the CR and any other necesarry info?
Any and all help is greatly appreciated, I am mechanically inclined and do all the work on my car, but hope to tear id down as little as possible/needed, and not afraid to get my hands dirty.
Old Jun 1, 2020 | 01:57 PM
muellersfan's Avatar
Default Re: 2000 Civic Si LS Vtec component identification help
You are in the wrong forum for the Frankenstein LS VTEC. Post your thread in the hybrid engine swap forum to access the hybrid swap gurus.
Old Jun 1, 2020 | 03:25 PM
ERA_Evil's Avatar
My bad, and thank you very much for the orientation, i opened the thread in the correct forum.
Old Jun 1, 2020 | 03:45 PM
Best of luck with the car and engine.
Old Jun 1, 2020 | 08:22 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You did not if you wish to receive the BEST help for your setup.
Best of luck.
Old Jun 1, 2020 | 09:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Any competent TUNER can tune the car without knowing a single part brand/stage/color at all... the information that you have discussed here is only important to you. The critical elements to tuning will be external parts like injector size. So take the car in to get tuned... and make your list when you have time.
yaucovtec
Mar 4, 2009 09:54 AM
LS-Vtak
Oct 4, 2007 09:20 PM
sour97
Sep 28, 2007 12:04 PM
DarkTeg94
Feb 13, 2005 09:49 PM
dub204
Jul 2, 2002 04:29 PM
