No fuel
Old May 28, 2020 | 11:10 PM
Redpandaz's Avatar
Default No fuel
I have a 1997 honda civic ex b18b swap turbo e85 chipped p28 obd1, the fuel pump doesnt turn on and the injectors dont fire, the injector has ground and has 12v, new fuel pump new main relay all fuses good good ecu, a23 a24 have ground, fan usually turns on when i have the key on run but isnt turning on, i have spark new distributor checked all the harness
Old May 29, 2020 | 01:10 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: No fuel
Check the wiring to the fuel pump. Put power to the pump to see if it primes you might have a short.
Old May 29, 2020 | 01:21 PM
Redpandaz's Avatar
Default Re: No fuel
I tried running a switch to the fuel pump and it turns on but the injectors still dont
Old May 30, 2020 | 03:16 PM
muellersfan's Avatar
Default Re: No fuel
Does engine start and run with starting fluid?
Old May 30, 2020 | 06:05 PM
Redpandaz's Avatar
Default Re: No fuel
If i have someone keep spraying it yes
Old May 30, 2020 | 06:08 PM
Default Re: No fuel
Sounds like your ECU is toast. Test the capacitors on it.
Old May 30, 2020 | 06:16 PM
Redpandaz's Avatar
Default Re: No fuel
How do i do that? Is there certain ones for fuel?
Old May 30, 2020 | 06:49 PM
Default Re: No fuel
Yep
How do i do that?
Desolder the electrolytic capacitors from the ECU. Many basic multimeters have a setting to test capacitors. Also inspect them for leakage.
B18C4-T
Aug 1, 2013 07:11 AM
PapiPezzi
19
May 31, 2013 03:38 PM
91civicwa
Nov 5, 2012 10:07 AM
ek201
Dec 20, 2010 10:21 PM
liquidrider
May 25, 2009 10:10 PM
