B16a2 Crank sensor hookup
I pulled the motor (b16a2) on my del sol and built the block.
put the motor back in and hooked everything up except the crank position sensor which I can't seem to find the plug for. it's mounted to the block under the lower timing cover but can't seem to find the wire to plug it in. I did end up with one extra plug but it's on the other side of the engine and doesn't make it. the harness is kind of jank from the previous owner could I just run wire to the connections on each of the plugs and see if it works ?
CTL
Mar 2, 2004 12:35 AM
