Speedo not working, D4 flashing! 01 lude
Old May 14, 2020 | 03:52 PM
Trevor Smith's Avatar
Default Speedo not working, D4 flashing! 01 lude
2001 Honda prelude automatic. Speedometer isn’t working. Just bought the car and We found a melted vss plug and replaced the plug, wires and the vss sensor. Still not getting a signal to the speedometer. Pulled the cluster to see if that was messed up and it was fine. Tested the voltage of each wire with car key on and had proper voltage and continuity on each wire. The “D4” on the dash is flashing and is throwing transmission code. Checked ecu and tcm and those were both good. Does anybody know what else to do or what is wrong with it?
Jdm_Ej8_Sedan
Nov 3, 2013 09:19 PM
Coricivic
Dec 11, 2011 07:01 AM
2000CivicEK
11
Jun 18, 2009 05:50 PM
new_climber
May 2, 2009 10:33 PM
Turbo Dan
20
Aug 5, 2008 09:46 PM
