99 civic b20 swap
Old Apr 28, 2020 | 01:25 PM
Cody Alan's Avatar
Icon4 99 civic b20 swap
hey guys i just swapped a b20v in my hatch, replaced flywheel,pilot bearing, throw out bearing ecttttt. long story short everything sounds fine going in gear/ shifting gears but whenever i get above 10 mph i hear a dragging noise like plastic dragging under car.. sounds like its coming from bell housing. The clutch grabs fine and everything sounds normal just when i accelerate that noise gets louder and louder. its almost like the throw out bearing isn't fully disengaging idkkkkk
Old Apr 28, 2020 | 01:36 PM
tony_2018's Avatar
Fish Twig
Default Re: 99 civic b20 swap
pressure plate rubbing against the tranny clutch housing.
Old Apr 28, 2020 | 01:38 PM
Cody Alan's Avatar
What do you mean the pressure plate is rubbing the clutch housing? I torqued everything to spec.
Old Apr 28, 2020 | 01:42 PM
tony_2018's Avatar
Fish Twig
Well, put it up on jackstands, engage the rear e-brake and test it again while its in the air. Have someone locate the sound.
Old Apr 28, 2020 | 02:47 PM
MADMKIII's Avatar
Does it correlate with road speed or engine RPM?
Old Apr 28, 2020 | 03:29 PM
Cody Alan's Avatar
I'm gonna say road speed but seems like higher rpm it isn't as bad. Idk to be honest cause I turned it around and parked it. But I did seem to get louder with road speed
Old Apr 28, 2020 | 03:59 PM
tony_2018's Avatar
Fish Twig
a dragging caliper?
Old Apr 28, 2020 | 04:05 PM
Cody Alan's Avatar
a dragging caliper?
I wish lol but I'm afraid it's either low on trans fluid or output shaft bearing 😒 but I swear it sounds like the throwout bearing is not disengaging but I have messed with the car, just trying to get ideas so I can start somewhere
Old Apr 28, 2020 | 07:58 PM
tony_2018's Avatar
Fish Twig
did you test drive this swap before putting it in your car? your OP made it sound like it happened after you swapped out the clutch...
xluigix47
Sep 28, 2014 02:21 PM
hugh_mann
May 28, 2013 12:50 PM
Tking10
Transmission & Drivetrain
Sep 1, 2011 11:00 AM
peekeesh
Jun 1, 2010 07:52 AM
CooBlueDAB
11
Aug 2, 2006 08:55 PM
