Car almost stalls after acceleration
I'm new to the forum and was hoping someone could point me in the right direction. I'm having a problem with my motor, seems like it almost stalls after pushing in the clutch after accelerating. And it only happens after the car is warmed up. So far I've verified the timing is correct, replaced the iavc, cleaned the throttle body, made sure there were no vacuum leaks, no air restrictions. Motor is a fresh rebuilt ls vtec, 1200cc injectors, wiesco 10:1 pistons on speedfactory rods, b16a head, boosted on 15psi, moates demon 2 tuned on chrome
Sounds like a tune problem. CRomE is a rudimentary tuning solution. If a Neptune program was used, at least the tools to tune the engine properly exist. Was it tuned before or after the fresh rebuild ?
I agree, the tune is a big unknown. worthwhile to investigate.
you said timing was checked, was the base idle set? not sure what the proper procedure is when running on chrome. I have seen a low base idle setting cause similar symptoms on a stock ECU/engine
curiousgpnoy
Feb 16, 2005 12:16 PM
