D16y8 automatic intake manifold
Old Apr 23, 2020 | 11:26 PM
Devin Cabison's Avatar
Default D16y8 automatic intake manifold
So i am currently having and issue with my d16y8 honda civic intake manifold. I changed it to the Skunk2 pro series intake manifold. I have everything together with the stock throttle body and i covered the back plate that goes to the manual IACV. I made sure there was no leaks and double checked the fittings. They were all secure and fastened down. So the problem is that when i start my car it revs to 3000rpm and after a second it surges from 1000rpm-3000rpm. With my old MAP sensor it went right to 5000rpm. I changed it with a new one and it was surging at 1000rpm-3000rpm.
Im thinking its either the IACV or the TPS sensor? But i dont know anymore and just really bummed that i wasted my money for something that doesnt work properly.
Old Apr 24, 2020 | 08:25 AM
subgeniusdude's Avatar
Default Re: D16y8 automatic intake manifold
Check your throttle body gasket,there is supposedly some minor differences between year models but I can't confirm personally,perhaps someone else could chime in but it's worth looking at. You could also have gotten an intake leak if you changed the intake manifold gasket and didn't get all the old material off which is a pita.
Old Apr 25, 2020 | 01:29 PM
ok i will check that for sure, i think it might be the intake manifold gasket. Or the throttle body. Thank you!!
Old Jun 29, 2020 | 09:49 AM
Did you find the problem ?
titi_vtec
Jun 29, 2010 07:59 PM
jdm_alex1996ex
Apr 18, 2010 01:43 AM
WrongWD
Northwest (Sales)
Jul 7, 2006 12:33 AM
All_Lag
17
Feb 26, 2003 12:34 PM
