Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Crank Shaft Seal Chipped Surface Advice
Old Apr 20, 2020 | 09:32 AM
spenceman's Avatar
Default Crank Shaft Seal Chipped Surface Advice
My sister's 2004 Civic D 1.7 had a fast leak out of the weep hole at the bottom of the lower timing cover and it appears I've found the issue. I used a seal puller and i don't think i used enough force to create that deep gouge. I believe that chip is on the oil pump? Should i go ahead and buy an oil pump or is there a decent way i can fill that surface (RTV?) and maintain a good seal. Any advice would be appreciated.
Old Apr 20, 2020 | 09:04 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Crank Shaft Seal Chipped Surface Advice
That isn't the oil pump with the groove, the groove is on the crankshaft snout.
SKF makes repair sleeves for this. I have just got done doing this repair on my VX as can be seen here:
https://honda-tech.com/forums/honda-.../#post52159136
It is not the easiest job to do as you have to drop the oil pan and take off the oil pump, which means replacing several seals but it can be repaired.
Old Apr 21, 2020 | 07:34 AM
spenceman's Avatar
So the outer surface of where the crank seal makes contact is the snout? okay i saw you can use the speedy sleeves on the shaft but wasn't sure about the other surface.
Old Apr 21, 2020 | 06:30 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The outer ring (that the seal slides into) is the oil pump and if you scratched it with your pick, you can always use a little permatex The Right Stuff on the scratch before installing the seal to fill the scratch and seal up the seal. The groove on the crank shaft snout though needs the speedi sleeve.
Chargerhemi06
Dec 4, 2014 05:43 PM
kenzo42
Mar 20, 2014 03:51 AM
1SickEG
Jan 28, 2013 03:54 PM
mattbatson
Jan 29, 2009 11:49 PM
NWHybrid
Jan 23, 2004 10:19 PM
