Would you guys choose a different head gasket than this for boosted setup?
Old Apr 18, 2020 | 03:13 PM
Stopsign32v's Avatar
Loved
Default Would you guys choose a different head gasket than this for boosted setup?
Going to go ahead and knock out the head studs when I do the timing belt and was wondering what head gasket I should get. For a mild 300whp setup would you guys suggest anything other than this one for a LS setup?
https://www.acurapartshq.com/oem-par...ZC1tYW51YWw%3D
And is there anything else I should do while I'm in there?
Old Apr 18, 2020 | 03:33 PM
TheShodan's Avatar
Moderator
Default Re: Would you guys choose a different head gasket than this for boosted setup?
OEM is best. Don't need anything else. You are good to go.
/thread
Old Apr 18, 2020 | 03:51 PM
Loved
That's what I thought. Should I copper spray the top and bottom? I think no but wanted to hear opinions.
Old Apr 18, 2020 | 03:54 PM
TheShodan's Avatar
Moderator
For OEM , for me I always do. Just a small layer enough to get "tacky" using permatex copper spray.
Old Apr 18, 2020 | 04:39 PM
Loved
Anything wrong with Felpro? Quite a bit cheaper and I can grab some other stuff while I'm at it at Rock Auto.
Old Apr 18, 2020 | 05:03 PM
NVturbo's Avatar
O.G. triple O.G.
Just go with Genuine Honda H/G and be done with. It's not that much more than a FelPro.
Old Apr 18, 2020 | 05:28 PM
Txdragon's Avatar
Avoid Felpro like covid..
Old Apr 18, 2020 | 05:55 PM
Loved
Sounds good, ordering OEM now
I figured with the head out of the way it would also be a good time to do the back of block catch can setup too.
Old Apr 18, 2020 | 05:57 PM
Loved
While I'm at it will I need a new OEM valve cover gasket?
Old Apr 18, 2020 | 06:42 PM
TheShodan's Avatar
Moderator
nope. not likely, unless it's torn in some way.
Old Apr 18, 2020 | 06:43 PM
TheShodan's Avatar
Moderator
never look at Rock Auto for anything Engine related.. stick to OEM..
Old Apr 19, 2020 | 02:41 AM
NVturbo's Avatar
O.G. triple O.G.
there are some exceptions to that. Last month, I ordered a Aisin water pump kit for my Lexus and it was the same as what Toyota was selling, but at a cheaper price. Other than the kit didn't come in a Toyota packaging, it fit perfectly and works fine.
Old Apr 19, 2020 | 05:42 AM
Loved
OEM head gasket is on the way and a Hondata intake gasket too.
Old Apr 19, 2020 | 05:52 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
OEM Honda gaskets and seals will save you a lot of grief in the long term, unless your over 500whp the OEM head gasket is fine, and some people push the OEM to som high high power levels
Old Apr 19, 2020 | 05:54 AM
NVturbo's Avatar
O.G. triple O.G.
Did you already picked up a set of fresh NGK spark plugs? Best price for them is Advance Auto Parts/Car Quest. Just search for the latest 25% off promo code and order them for pick-up at your nearby store.
Old Apr 19, 2020 | 06:57 AM
Loved
I still need to get some NGK plugs and NGK wires. Also wondering if I should go through the distributor and see if everything is good and OEM. Is there a better rotor than the OEM that people are using? I don't think much else needs to be touched.
Old Apr 19, 2020 | 07:01 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
stock replacement cap and rotor button is fine. Use a heat range 7 NGK plug .
Old Apr 19, 2020 | 07:08 AM
NVturbo's Avatar
O.G. triple O.G.
NGK Plug wires -- NGK 8041 (HE82)
NGK spark plugs -- NGK 4644 (BKR7E)
Old Apr 19, 2020 | 08:08 AM
Loved
I'm not currently boosted and will be driving around for a few more months before I am. Still have to do the clutch and flywheel and other odds and ends.
What are the stock heat range NGK plugs? I need a set of them too for right now.
Old Apr 19, 2020 | 08:17 AM
turboLScrx's Avatar
25 Year Member
Loved
Community Favorite
stock range is a 6 if I’m not mistaken
Old Apr 20, 2020 | 10:13 AM
TheShodan's Avatar
Moderator
correct. So a BRK7E-11 7 heat range is what you need.
Dave_Dc2
Jan 13, 2010 01:51 AM
jdmomar
Jan 25, 2006 01:27 PM
ARACER25
Oct 23, 2003 10:31 PM
1.8T_EG
Sep 24, 2002 01:53 PM
Albino Dragon
Jan 24, 2002 12:26 PM
